Author Topic: Germicidal lamps that don't produce UV  (Read 8484 times)
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Germicidal lamps that don't produce UV « on: February 19, 2026, 12:36:16 AM » Author: LightsAreBright27
I remember that some people wanted clear fluorescent lamps, that don't produce UV. I found a fake lamp, that doesn't use quartz glass, so doesn't produce UV-C.
I have 2 germicidal lamps, a real philips G6T5, and a fake "philips" G6T5.
The real lamp was bought at an authorized philips distributor, and came in a thin polystyrene sleeve with warnings all over it. The fake lamp was included with a ballast for free, and came with no sleeve.
The fake lamp didn't even have crimps on the pins, so the lamp didn't work at first. I had to put some solder in the pins to even make it work.
Also, the etch of the fake lamp rubbed off easily.
Then, I noticed a color difference between the real and fake lamp, especially when I kept it on paper. I noticed that the real lamp made the paper glow blue (due to fluorescence) while the fake lamp made the paper glow cyan (just like the lamp itself).
Then I used a UV-C test card. The real lamp made the test card glow green, while the fake one didn't.
I have come to the conclusion that the fake lamp actually doesn't use quartz glass, and is just normal glass. The fake lamp is the equivalent of clearing the phosphor from a normal tube. That means no UV-C comes out of it.
245v 50Hz
Lampwizard
Re: Germicidal lamps that don't produce UV « Reply #1 on: March 02, 2026, 05:40:11 AM » Author: Lampwizard
Linear germicidal lamps are not made of quartz; instead these are made of soft glass with a certain dope to make it transparent to the 254nm wavelength while intransparent for the ozone-producing 185nm wavelength.
Fake or not: I would not take my chances with this uncoated lamp when it comes to the unshielded eye and skin. A UV-C test card may yield inconclusive results.
Philips colour 27: best fluorescent tube colour.
