Author Topic: Today's EOL  (Read 7502 times)
suzukir122
suzukir123
Today's EOL « on: February 24, 2026, 06:21:10 PM » Author: suzukir122
Got a lamp that reached an EOL today? Post about it here.
Unfortunately I've got a lamp that reached EOL unexpectedly... one of my better CFL's... a 15w GE BIAX CFL, went EOL today. A component within the base
failed, so it did not light up when I flipped the switch on. Showed no signs of EOL earlier in the day and worked perfectly fine. I'm assuming it might've
been the starting capacitor that failed but I'm not sure. This was a Programmed Start CFL... the tube portion did NOT fail, so there was no EOL show, and
fair weather end blackening from years of usage. I've used that GE BIAX CFL in my kitchen since 2020. This is unfortunately the second 15w BIAX to fail
unexpectedly. The first one failed back in 2022. I took a pic of that one back then, shown here:
https://www.lighting-gallery.net/gallery/displayimage.php?album=1854&pos=40&pid=209478.
Interests:
Emersyn
Re: Today's EOL « Reply #1 on: February 28, 2026, 07:23:30 PM » Author: Emersyn
Not really today, but I have a Sylvania lamp that is just so close to EOL but it somehow still works without actively burning out (on an electronic ballast!) https://www.lighting-gallery.net/gallery/displayimage.php?album=lastup&cat=14865&pos=1&pid=266964
suzukir122
suzukir123
Re: Today's EOL « Reply #2 on: February 28, 2026, 07:50:55 PM » Author: suzukir122
@Emersyn,... not sure what's going on there. What kind of electronic ballast is used in that fixture? All four ends are heavily blackened, which leads me to
believe it may be a ballast (or ballasts) issue... maybe.
That fixture could be operating much, much better than that.
Also, does that fixture encounter any sort of... frequent switching...? Just wondering.
To anyone reading this, I forgot to mention: ballast EOL's or the EOL's of anything that aids the ballasts in any way, counts as well.
... and you guys may know this already, but: this is not at all limited to just Fluorescent. :lol:... just thought I'd throw that out there.
Interests:
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: Today's EOL « Reply #3 on: March 01, 2026, 04:34:53 AM » Author: LightsAreBright27
I had this F20T12 daylight lamp that was EOL. I didn't use it because it was rare. Today I wanted to fire it up just for a few seconds (not long enough to lose vacuum) using a GE 2x 40w instant start ballast. But even running it for 3 seconds made it lose vacuum with a hiss. After losing vacuum the endcap on the EOL side fell off. Here's the lamp (a while before I ran it today):
https://www.lighting-gallery.net/gallery/displayimage.php?album=lastup&cat=14396&pos=67&pid=261314
245v 50Hz
suzukir122
suzukir123
Re: Today's EOL « Reply #4 on: March 01, 2026, 07:12:07 AM » Author: suzukir122
@LightsAreBright27, the endcap falling off also sounds interesting. It's possible that the endcaps weren't glued to the tube very well.
I've had this happen on very rare occasions, really only with cheap PL-S lamps, and cheap smaller T5 lamps. I've never encountered a T12 lamp
with this issue. Although I have encountered T12's with endcaps that have too much glue, and endcaps that were attached in a crooked manner... Sylvania...
Anyways, completed a weekly check of all of my fluorescent lamps in use in my apartment. It appears as if none of my CFL's are ready to EOL yet, and of
course, all twenty two of my F30T12's are running fine, as well as my newest addition: an F15T12 in a strip fixture. That's running fine as well aside
from swirling. Hah... in short, I've got nothing new for this thread yet. :lol:
Interests:
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: Today's EOL « Reply #5 on: March 01, 2026, 07:34:58 AM » Author: LightsAreBright27
@suzukir122 on some extreme cases I've had endcapls fall of taking the lead of the tube as well! I had an F20T12 daylight (a different one, not the eol one) whose endcap twisted off with the lead wires, making the tube completely unusable!
https://www.lighting-gallery.net/gallery/displayimage.php?album=8026&pos=2&pid=265258
When they get loose, i just put some tape around it making sure it is aligned with the other side, or else the tube doesn't work in fixtures
245v 50Hz
Emersyn
Re: Today's EOL « Reply #6 on: March 01, 2026, 09:23:05 AM » Author: Emersyn
That fixtures has electronic rapid start ballasts and I think they're okay, though I have noticed to my alarm that sometimes a wire will slip out of a socket which causes cathode heating issues. The lamps in this case were installed at the same time, and then very heavily used. I would say they had a pretty normal amount of switching. Though as seen in this photo, those electronic RS ballasts don't always have reliable heating... https://www.lighting-gallery.net/gallery/displayimage.php?album=8528&pos=1&pid=266656
It is interesting to see the different paths that the tubes take when they go EOL, the middle two just burned out, while the right one went mercury starved. Believe it or not, the sock on the other end of the dim tube is even longer (though less dark) then the one in the photo.
« Last Edit: March 01, 2026, 09:25:34 AM by Emersyn » Logged
suzukir122
suzukir123
Re: Today's EOL « Reply #7 on: March 01, 2026, 10:00:43 AM » Author: suzukir122
@Emersyn... wire slipping out of a socket... depending on what kind of electronic rapid start ballast this is, that could be a very big issue. :'-)
... Are you ever going to replace that ballast with a higher quality magnetic HPF Rapid Start ballast?
@LightsAreBright27, long time ago but I've actually broken a T5 lamp due to twisting the lead wires. The lead wires cracked the cathode and the lamp
basically exploded. Loud boom. Scared the CRAP out of me. This of course was when I was a kid. lol
Interests:
Emersyn
Re: Today's EOL « Reply #8 on: March 01, 2026, 10:19:44 AM » Author: Emersyn
Yeah, but I just tested it and all the wires seem to be in. Since it's an HF ballast, I unfortunately can't test the voltage of their heating.
At the moment no, I don't really have any good ballasts to put in. I used my last good 2 lamp ballast in another fixture recently and it wouldn't be that conducive to put a 1 lamp ballast in the fixture lol
Re: Today's EOL « Reply #9 on: March 01, 2026, 04:57:17 PM » Author: xmaslightguy
Quote from: Emersyn
This is not a problem of the ballast or the fixture, but the sockets themselves...
The little metal tabs that hold the wires can become bent/lose their springy-ness so they don't grip very well ... especially if ballasts have been changed a few times.  It might at first 'feel like' the wire is in place good, but in reality it isn't & ends up popping out fairly easily later on.
Depending on how the sockets are made, some can be taken apart & its simply a matter of bending the tabs just slightly so they again are putting pressure on/holding the wires tight. (I've done this a number of times!).
Some though don't come apart, so you'd have to replace 'em (they're not that expensive so its well worth doing)
suzukir122
suzukir123
Re: Today's EOL « Reply #10 on: March 01, 2026, 07:01:58 PM » Author: suzukir122
@xmaslightguy, highly agreed. I actually had to take apart literally every socket in all five of the "LED ready" fixtures in my upstairs loft, to get them prepared for the wiring of each HPF magnetic Rapid Start ballast that I installed. I had to open up the "back door" of each socket, force the tabs up to release the LED ready wiring, insert the copper portion of the ballast wiring, then re-bend the tabs downward to further guarantee official contact with the tabs and the copper portion of each wire. After that, I'd close the "back door" of each socket. After applying power supply to the ballast, using only one lamp, I checked for visible electrode filament heating on both sides of each ballast. I did this with all of my fixtures, and all of them passed the test. (Except for that one ballast I told you about in the middle fixture. That is the only one that had an issue with filament heating. I'll be checking that ballast soon.)
But all 11 of my fixtures are working flawlessly with each and every start up so far, although I know for a fact there was probably an easier way for me to handle the "LED ready" socket wiring during ballast installation.
But yeah... the tabs making contact with the copper portion of the ballast wires... that's a big deal. It may seem as if the wire is snug in place, but that does not mean the copper portion of the wire is making contact with the tabs, @Emersyn.
Interests:
Emersyn
Re: Today's EOL « Reply #11 on: March 02, 2026, 07:02:41 AM » Author: Emersyn
Unfortunately the sockets in that fixture have the stapled cardboard backings so I don't think that they can be taken apart and then put back together. I do have a few fixtures with more modern sockets but I just in general have a socket shortage. I ran out of good sockets, so my 2x F20 wraparound's sockets are all broken but they're nothing super bad. I've been thinking about maybe getting an order of black sockets too since they always look nice.
suzukir122
suzukir123
Re: Today's EOL « Reply #12 on: March 02, 2026, 11:44:27 AM » Author: suzukir122
There's tons of sockets available on Ebay. The "JESLED" non shunted sockets look somewhat similar to the ones in the fixtures in my upstairs loft,
although mine aren't the slide in versions. The "back doors" of those sockets look to be easier to remove. Maybe those would work.
There's also some from "HH Fluorescent" that look similar as well.
Interests:
Emersyn
Re: Today's EOL « Reply #13 on: March 02, 2026, 12:11:24 PM » Author: Emersyn
The only problem is that my mom is picky about me getting lighting stuff because she thinks that I will run out of space (she's been thinking that for over 7 years, in which I got multiple 4ft fixtures and hundreds of lamps and I still have space lol) but hopefully I can get them!
bulb_tester2009
Re: Today's EOL « Reply #14 on: March 02, 2026, 09:11:45 PM » Author: bulb_tester2009
It seems that no mother wants her child(s) to make the house messy because of collecting things :wndr: Because I had purchased a lot of HIDs and fluorescent lamps (including two outdoor floodlights and a lot of EOLed lamps replaced from my home), my room became a mess a long time ago. Every time she enters my room, she gets very angry, even though I have already tried to arrange them in order :-[
:hps: Poor quality lamps in my collection are prohibited. Most of them have been used for my destructive experiments and ballast tests.
