Author Topic: Starter for F4 F6 F8 Single lamp preheat ballast at 120V, 240V, 277v  (Read 3368 times)
Ken1
Starter for F4 F6 F8 Single lamp preheat ballast at 120V, 240V, 277v « on: March 06, 2026, 04:54:25 PM » Author: Ken1
Hi, I would like to know if the starter needed for a single lamp ballast for a F4, F6, F8 lamp is the same or different for each of the following ballasts: 120V ( Robertson L48) , 240V ( Robertson L4835 ) , and 277V ( Robertson L6827 ).
Multisubject
Re: Starter for F4 F6 F8 Single lamp preheat ballast at 120V, 240V, 277v « Reply #1 on: March 06, 2026, 05:31:37 PM » Author: Multisubject
Yes, as long as the lamp is a 4W, 6W, or 8W tube, an FS-5 or equivalent starter should work just fine at any of those supply voltages. I believe the important part is the lamp's voltage, not the main supply voltage, so there shouldn't be a difference.
PlasmaAddict
@MernokiMegoldasok nagy.peter.01
Re: Starter for F4 F6 F8 Single lamp preheat ballast at 120V, 240V, 277v « Reply #2 on: March 08, 2026, 03:42:08 PM » Author: PlasmaAddict
It would definitely work. The only question is, what would the OSHA guy say when he sees a starter socket rated at 250V used in a 277 V fixture?
Plasma, the 4th state of matter is the most beautiful form of lighting that ever existed.
