Author Topic: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions)  (Read 38440 times)
PlasmaAddict
@MernokiMegoldasok nagy.peter.01
Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « on: March 08, 2026, 08:56:31 AM » Author: PlasmaAddict
Can someone give more details about gas fillings in T5 fluorescent lamps?
I know that the classic 4, 6, 8, 13 W lamps have argon fill, but I'm not sure about others.
There are 11, 15 and 16 W lamps which have the same length as 6 and 8 W lamps.
And T5 HE and HO. Is the only difference in the electrodes or do they have a different gas filling pressure or even a different gas like krypton?
I know that T8 16, 32 and 51 W 'Eco' (Philips name) or 'ES' (Osram name) have xenon as the buffer gas, so maybe energy saving T5 tubes also have something other than argon. Even T5 HE and HO comes in a more recent energy saving version, like Philips Master TL5 ECO 25, 50, 73 W.
« Last Edit: March 23, 2026, 04:43:57 AM by PlasmaAddict » Logged
Plasma, the 4th state of matter is the most beautiful form of lighting that ever existed.
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #1 on: March 16, 2026, 03:25:01 AM » Author: RRK
I just had a chance to play with some nice old Osram's T5 HE's and HO's, original German and Italian. I used my spectrometer to capture spectra from cold lamps (mercury not yet fully evaporated) to get the idea of what buffer gas fill is. Based on near-IR signature I see, a dense cluster of IR lines, I can say the fill is pure Ar, no Xe or Kr added. About the same that I see for small T5's and CFLs too. I remember reading somewhere too that the fill gas for T5 tubes is just plain argon. Note that some lightweight inert gas with high ionization potential as Ne or He may slip in unnoticed by this method, as it is not preferentially excited in the mix, but I did not see Ne pattern even around cathodes, where it can show up.
I don't have access to any newer 'economy' T5 tubes, so can not tell for them.
See, old school T5 13W runs at the same current as modern T5 HE 14W (170 milliamps), is about the same size and is almost mutually electrically compatible.
« Last Edit: March 16, 2026, 03:34:51 AM by RRK » Logged
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #2 on: March 16, 2026, 07:04:30 AM » Author: dor123
But 14W T5 HE aren't designed to be operated on the magnetic ballasts of 13W T5.
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #3 on: March 17, 2026, 12:48:19 AM » Author: RRK
@dor123 Thanks for sharing this really hard to find information ;)
Officially, no. In practice I believe 14W HE will run on 13W magnetic just right, may be with just a minor lifetime penalty due to a higher current crest.
13W tubes run on 14W HE electronic ballast with a slight overdrive. IEC 60081 datasheet prescribes 150mA for 13W tube on HF, 14W ballast will run it at 170mA, but still within IEC 60081 spec (180mA max). Nice T5 HE programmed start electronic ballasts are so ubiquitous today, not much need to play with magnetics.
« Last Edit: March 17, 2026, 12:54:10 AM by RRK » Logged
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #4 on: March 17, 2026, 02:08:24 AM » Author: Medved
The topic is about gas fill, the magnetic ballast (aka low frequency operation) compatibility about electrode design.
These two aspects do not have that much in common...
dudam001
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #5 on: March 17, 2026, 05:27:04 PM » Author: dudam001
@dor123 It wouldn't hurt anyone to try, Dor.
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #6 on: March 17, 2026, 08:02:49 PM » Author: James
T5 fills tend to be a bit complex, and vary a lot between different manufacturers. Based on the design of experiments it transpires that there are multiple different compositions that deliver basically the same initial performance.  Occasionally it was found that even though some are identical in terms of initial photoelectric data, there are differences that appear as the lamps age, or in the ignition behaviour, sensitivity to ambient temperature variations, and other effects like arc swirling and snaking.  As a result there were quite frequent changes over time, in search of the optimum conditions.  Same of course for all other parameters like the electrode geometry and emitter coating weight and chemistry.  At some manufacturers the following optimised fills were gradually worked out for T5 types:
T5 Miniature 6W & HO 11W : Argon 1.6mbar
T5 Miniature 8W & HO 15W : Argon 2.1mbar
T5 Miniature 13W & HO 25W : Argon 3.15mbar
T5 Emergency 6W: Cronigen 2.7mbar
T5 Emergency 8W: Cronigen 3.2mbar
T5 FHE 14W: Argon 2.45mbar
T5 FHE 21W: 89:11 Ar:Kr 2.15mbar
T5 FHE 28W: 89:11 Ar:Kr 2.25mbar
T5 FHE 35W: 79:21 Ar:Kr 2.75mbar
T5 FHO 24W: 51:49 Ne:Ar 2.75mbar
T5 FHO 39W: 51:49 Ne:Ar 2.15mbar
T5 FHO 49W: Argon 2.75mbar
T5 FHO 54W: Argon 3.65mbar
T5 FHO 80W: Argon 3.15mbar
T5L8 24W 15in: Argon 2.2mbar
T5L8 28W 2ft: Argon 2.65mbar
T5L8 45W 3ft: Argon 3.45mbar
T5L8 54W 4ft: Argon 4.1mbar
T5L8 80W 6ft: 75:25 Ar:Kr 2.5mbar
T5 FHE Eco 13W: 75:25 Ar:Kr 2.05mbar
T5 FHE Eco 19W: 55:45 Ar:Kr 2.0mbar
T5 FHE Eco 25W: 45:55 Ar:Kr 2.0mbar
T5 FHE Eco 32W: 49:51 Ar:Kr 2.0mbar
T5 FHO Eco 20W: 89:11 Ar:Kr 2.0mbar
T5 FHO Eco 34W: 96:4 Ar:Kr 2.0mbar
T5 FHO Eco 50W: 40:60 Ar:Kr 2.05mbar
T5 FHO Eco 45W: 40:60 Ar:Kr 2.0mbar
T5 FHO Eco 73W: 79:21 Ar:Kr 2.0mbar
PlasmaAddict
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #7 on: March 18, 2026, 05:39:08 AM » Author: PlasmaAddict
Thanks a lot, James.
If 2 tubes were made with the same diameter and same length, same gas filling composition but different gas filling pressure, operated at the same current, am I right to think that the tube with the higher gas filling pressure would have the higher voltage drop? How does it scale, would a tube with 3x the gas pressure have 3x the voltage drop?
What is Cronigen in emergency lighting tubes? Google doesn't seem to know anything about it.
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #8 on: March 18, 2026, 07:20:10 PM » Author: RRK
@James
Interesting. According to your table 24W HO tube should be filled with 51:49 Ne:Ar.
I have a nice green 24W HO by Osram. Circa 50/50 Ne/Ar mix is assumed to show some neon glow in the cathode area, especially with a low current, right? I probed this lamp with a neon tester, touching both the glass and electrode pins. Pure green glow, no red/orange tint both times. Even around the filament. Date code of my tube is z8F3a. Exactly the same for 39 and 54W tubes I have, too.
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #9 on: March 19, 2026, 05:11:15 PM » Author: James
To see the neon glow through the phosphor coating is not easy.   you often have to place the lamp in a deep freezer to solidify the mercury and then it becomes much easier.  On the other hand, all of these gas fillings seem to have changed so frequently and between different manufacturers, it’s possible there is a different fill in your Osram lamp.
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #10 on: March 21, 2026, 05:13:51 AM » Author: RRK
@James
Well okay ;)
So you convinced me to torture this little rare tube by freezing it at -18C for some time and then running briefly from 20mA neon transformer. Here you can see the spectrum I captured in the area near the electrode. A bit noisy as the light is weak at small current. For comparison, also the spectrum from the middle of discharge column with a cold tube (typical Ar infrared signature) and from a hot run-up tube (Ar lines suppressed, only green Tb phosphor + some mercury now).
The only suspicious spectral line which may belong to Ne I see with cold tube near the cold cathode is a small peak at ~649nm. Does not look to be typical Ne wavelength too, but who knows.
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #11 on: March 21, 2026, 07:03:08 AM » Author: RRK
Red T5HO 24W Osram tube tortured in the name of Science! ;) Gods of fluorescents, forgive me...
Run freezed at 20mA, shot near the electrode, then at the middle of the tube, run-up full current. I believe in the blue-green area I see barium and strontium lines from atoms sputtered off the cathodes of this poor little tube. I feel the pain you suffered, won't do it any more, trust me :)
I can not see any sign of neon present.
Also you see red phosphor YOX, Y2O3:Eu bearded red line spectrum in a full glory, here not polluted by yellow and orange bands of terbium phosphor.
Spectrum from the green tube also contains a strange peak at ~589nm, it *may be* a line from neon, but usually cathode glow of neon is dominated by slightly shorter 585nm line.
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #12 on: March 21, 2026, 02:18:24 PM » Author: RRK
Rather recent Chinese Osram 24W/HO 840. Still no trace of Ne, some signs of alcali earths sputtering with glow discharge at 20mA.
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #13 on: March 21, 2026, 02:27:16 PM » Author: RRK
Now! Gotcha! Rather old original Italian Osram FH 21W/840 *HE*! Here I 100% agree with @James listing. Dominant krypton lines with some weak argon lines. Krypton having lower ionization potential will dominate even at low percentage.
Also, my own handmade cold cathode tube with pure krypton as a spectral reference!
Re: Gas filling in T5 fluorescent tubes (classic, HE, HO, energy saving versions) « Reply #14 on: March 21, 2026, 03:15:00 PM » Author: RRK
And finally, some interesting offtopic on spectral investigations ;) A crime case of some circa 2023 recent shitty Russian 36W T8 tube from my home, probably originated from Smolensk, but not branded Russian Osram. It got mercury starved and was replaced, but I kept the tube out of curiosity. It burns dim whitish with pronounced stirations. As you can see the spectrum shows near - 100% krypton fill, and no trace of any foreign molecular gas like oxygen or nitrogen. So it got really mercury starved, not leaked! You see only very weak  mercury lines and very weak phosphor excitation, as krypton has just a weak UV and at very short wavelengths, halo phosphor is insensitive to these. I do not have a starved argon tube yet to investigate, though.
