Author Topic: What is the worst LED bulb you’ve seen?  (Read 27760 times)
Lightingeye60
What is the worst LED bulb you’ve seen? « on: March 18, 2026, 04:06:01 PM » Author: Lightingeye60
I’ve been noticing that LED bulbs keep getting worse and worse in build quality over time, but light quality and CRI seems to be getting better, but what is he absolute worst LED bulb you’ve seen?
It can be for anything, poor light quality, uneven lighting, short life, etc.
marcopete87
Re: What is the worst LED bulb you’ve seen? « Reply #1 on: March 19, 2026, 07:29:22 AM » Author: marcopete87
Some led lamps 15 years ago: cheap 5mm leds packed without heat management with absurd specs (like a 1.5W lamp rated as an 60W incandescent lamp).
They weren't even cheap
wishus
Re: What is the worst LED bulb you’ve seen? « Reply #2 on: March 22, 2026, 08:50:07 AM » Author: wishus
I bought two 4-packs of GE Reveal HD 2850K 5W and one 4-pack of the 8W to relamp the hallway lights.  ALL of them had failed after 8 months, and some started failing after only 2 months. None of the fixtures are enclosed or recessed either, so there's no excuse for this.
I will never buy GE bulbs again.  In fact I will never buy any premium price LED bulbs again, I just buy the cheapest bulbs I can find.  I am not wasting money on that again. Absolutely enfuriating.
Interested mainly in discharge lighting (mercury, sodium, neon) and also old and unusual incandescents.
Re: What is the worst LED bulb you’ve seen? « Reply #3 on: March 22, 2026, 08:37:59 PM » Author: wide-lite 1000
 The worst I've bought was a Feit RGB bulb . IT SUCKS !!!!  It has NO memory circuit in it so you have to set the color/Light pattern everytime you turn it on using a tiny button on the side of the neck . Accidentally dropping this P.O.S. was the best thing that ever happened to it !!
Lightingeye60
Re: What is the worst LED bulb you’ve seen? « Reply #4 on: March 22, 2026, 11:13:06 PM » Author: Lightingeye60
I’ve never had that bad luck with GE LEDs, especially the snow cone versions, the ones I had worst luck with were Great Value and EcoSmart (store brands). Never tried Sylvania. Mid range Philips seems okay (as long as it’s not the LED filament warm glow variant), though snow cone warm glows don’t seem too bad. Premium price LEDs are often better quality but are more expensive.
I just visited a house, and I’m not sure of brand but it was a bathroom light with two LEDs on the ends and an incandescent in the middle, not enclosed, all in individual glass shades, the one of the LEDs was flickering while the incandescent was going strong. They were standard snow cone LEDs I think. Absolutely infuriating! I’m guessing the next bulb to fail is the other LED.
LightsoftheWest
SRP for life.
streetlightian
Re: What is the worst LED bulb you’ve seen? « Reply #5 on: March 28, 2026, 06:41:24 AM » Author: LightsoftheWest
The worst I have had was some Amazon special LED deformable garage light. It lasted for about two years until it overheated to the point where the plastic diode lens panels started melting. Destroying that thing was the best thing that ever happened to it. Found a replacement at Costco that's held up far better.
LG's North American luminaire identification specialist
xelareverse
Re: What is the worst LED bulb you’ve seen? « Reply #6 on: March 29, 2026, 08:44:46 PM » Author: xelareverse
For household use, the last of the made in USA Sylvania bulbs. Not only do they have a short life span, but they have a design flaw that makes them dangerous. The envelope with the LED filament arrays is glued to the base. That glue is right where the heat from the driver and the heat from the LEDs meet which causes the glue to fail. These will then fall out of the fixture leaving only the driver and base portion behind. So if used in an open fixture, they can fall right out of it and shatter on the floor. I'm lucky that I haven't had any shatter (they bounced instead) but I've had a couple fall out. I've removed them all from use.
