Author Topic: Purpose of strangely shaped clear envelopes  (Read 5799 times)
Multisubject
Purpose of strangely shaped clear envelopes « on: April 29, 2026, 11:52:31 AM » Author: Multisubject
This seems to be mostly a US problem, in other Europe most of the time clear lamps are tubular and diffused lamps are elliptical. However particularly with low wattage and retrofit lamps, this does not seem to be the case in the US.
For example, most clear 360W HPS retrofit lamps are BT-37 shaped, which matches their MV counterparts. But why not make them tubular (like normal 400W HPS)? The envelope is clear anyway, making it bulb shaped doesn't make a difference.
And for smaller regular HPS wattages this is still the case, most 35-150W HPS lamps are not tubular in the US. Often they are BT, E, or ED shape. Is it to reduce the surface temperature of the envelope?
And of course out larger wattages (250-1000W) are almost never actually tubular but rather a strange elongated elliptical-ish shape. How did this shape come about? Why not just use plain tubular like the rest of the world?
Now I know for things like MV and MH (which are usually nitrogen filled in the outer envelope), having a tubular envelope can sometimes restrict their use to vertical only so the envelope doesn't end up melting. But I haven't heard of this happening with HPS before.
Anybody have any ideas?
Re: Purpose of strangely shaped clear envelopes « Reply #1 on: April 30, 2026, 12:37:51 AM » Author: Medved
Mechanical robustness against the external atmospheric pressure?
The most robust shape is a sphere, the least (assume smooth surface now) is flat panel. The curvature helps to make sure no part of the material is exposed to tension and no leverage amplifies any of the stresses.
These lamps use rather long internal structures, so true ball becomes impractically big.
The tubular has curvature only along one axis but becomes rather slim shape along the lamp working structures (the arctube with its frame and connection), elyptical across both direction, so it is stronger. Plus has its glass further away from the hottest part of the inner workings, so does not need to work at that high temperatures and that high temperature gradients.
On the other end the tubular means it could start from a tube - an easier format to make for a high volume production, which may make it cheaper even when eventually using a bit more material or requiring a bit more consistent structure. Elyptical requires more forming, which may make it more expensive for processing and more prone to defects that make it weaker.
At the end both are an engineering compromises, neither a "clear winner", their exact choice was dictated by the weaknesses and strengths of the particular plants and processes they originated from, but to big extend also the legacy - continue making what has been working and what people were used to in that area, e.g. also what the various fixtures became designed for (lamp anchoring mechanisms,...) and what the lamp engineers were familiar to work with (so they know what they can get away with and what not to do in their designs when using given shape, so avoid mistakes).
Ugly1
Re: Purpose of strangely shaped clear envelopes « Reply #2 on: April 30, 2026, 02:50:41 PM » Author: Ugly1
I may be mistaken on this( can’t find my catalogs right now), but I believe the original 1000 watt high pressure sodium lamp was a T18 bulb,ANSI S52XA-1000, as opposed to the later E25 bulb, ANSI S52XB-1000.
LightBulbFun
Re: Purpose of strangely shaped clear envelopes « Reply #3 on: April 30, 2026, 03:09:23 PM » Author: LightBulbFun
from what I have read and responses i have got from lighting engineers over the years when I have asked similar questions
the principle reason, is mechanical/optical compatibility, and quality of materials and ease of manufacture
for retrofit lamps, you want it to be the same shape and size as the lamp its replacing, to be as mechanically and optically compatible as possible
the reason for the funny shape of US 250W-1000W HPS lamps is because of material and ease of mfg, US glass tends to be lower quality than European glass and so having a slightly bulged bulb means a slightly cooler bulb, less out-gassing and degradation of the glass, and also I it makes it easier to centralise the bulb over the stem mount assembly on the sealing machine
Re: Purpose of strangely shaped clear envelopes « Reply #4 on: May 15, 2026, 02:52:45 PM » Author: James
Another reason is that the three main American lamp glass manufacturers, GE, Corning and Sylvania, changed to a unique glass composition which has a lower softening temperature than European lamp glass manufacturers.  The lower temperature processing allows production to run faster and at lower cost, but also leaves more hydroxyl ions trapped in the glass.  At lamp operating temperatures those dissociate and the free hydrogen interferes with ignition of the arc.  To prevent that effect, the simple solution for the Americans was to make the bulb diameter larger so that it would run cooler.
