Author Topic: UVA pumped LEDs?  (Read 13554 times)
Laurens
UVA pumped LEDs? « on: April 30, 2026, 07:59:05 AM » Author: Laurens
Apparently those exist, and they have the benefit of eliminating the below-par teal (blueish green) reproduction of cool white LEDs. Those often have a bit of a gap between the pump diode direct radiation, and the YAG phosphor emission. And of course no blue emission above 440nm.
Has anyone ever seen this technology in real life? I attempted to buy some from Aliexpress - wide range LEDS supposedly putting out the whole 340-800nm spectrum. Of course i was sceptical and i don't expect much from 10 leds for €3,29 shipped to the Netherlands, but i do wonder if there are actual reliable sources, and if this technology is already in use somewhere.
What i received were bog standard plant grow leds with the 450nm pump diode and a red phosphor centered around 650nm.
Re: UVA pumped LEDs? « Reply #1 on: May 01, 2026, 01:09:35 AM » Author: RRK
GE did 405nm pumped high CRI white LEDs very very long ago under the trademark Vio LED. Probably forgotten now. 2009 story...
Violet and UVA pumped WLEDs would of course lose in efficiency to classic WLEDs considerably due to extra Stokes shift and extra conversion in blue light.
« Last Edit: May 01, 2026, 01:36:33 AM by RRK » Logged
Re: UVA pumped LEDs? « Reply #2 on: May 01, 2026, 03:09:48 AM » Author: James
Indeed GE's VioLED is the only one I am aware of which became commercially successful, for a short time.  There was another company in Mexico that briefly produced A-line retrofit incandescent lamps with the same technology of a remote phosphor coated glass bulb around UVA LED emitters around 2012-2015, but they also quickly disappeared, and I forget the name.  UV-pumped technology is considerably better in terms of colour quality and colour stability, but has the penalty of higher cost and lower efficacy.  During the mid-2000s LEDs were developed with a view to achieving much greater performance than is commonplace today, until manufacturers realised that actually selling price and energy efficacy are the only things most consumers care about, and many of the innovations aimed at better quality of light had to be abandoned.
Laurens
Re: UVA pumped LEDs? « Reply #3 on: May 01, 2026, 05:01:47 AM » Author: Laurens
Aah damnit.
Near zero chance to find them to add to the collection, i guess. Even 'plain' remote phosphor ones are hard to find locally.
By now UV and near UV leds have gotten pretty common so i guess it should be possible to see if production would be economically possible these days - if the efficiency would be acceptable.
It would be fun to experiment with remote phosphor stuff as a hobbyist, but so far i haven't come across vendors of the right phosphors in hobbyist amounts.
E: found this: https://img.archilovers.com/blog/3648_01.pdf
A CRI of 70 and 85 isn't that great in today's context. But i know for certain (i have some 2003...2009 LED lamps) the 80 cri common warm white-ish LEDs are absolutely ugly so they could definitely have been better than what was on the consumer market at that point in time.
Either way, i'd like to add somethng like this to my collection of oddball or historically significant LEDs. Same goes for the pre-Nichia era blue LEDs.
« Last Edit: May 01, 2026, 05:07:22 AM by Laurens » Logged
Re: UVA pumped LEDs? « Reply #4 on: May 01, 2026, 11:09:00 AM » Author: RRK
UVA sensitive phosphors are easy to get from Aliexpress. Most of long afterglow inorganic stuff will work with UVA and for DIY remote phosphor even organic phosphors are OK. Probably you even can pick some at local art stores. Fluorescein and rhodamine solutions look fun with UVA and blue light too! There is also some new bright organic phosphor stuff like pyranine.
Laurens
Re: UVA pumped LEDs? « Reply #5 on: May 05, 2026, 09:32:38 AM » Author: Laurens
Found something!
https://www.ledrise.eu/led-strips-modules/our-profesional-led-strips/led-strip-linearz-sunlike-cri97-2700-lm-m.html
Now to find a place where you can actually buy them EDIT they literally sell them on that site, and they ship from germany. Cooooool. Probably gonna order a bunch of these.
Wouldn't call 405nm UVA but at least it's a different strategy than the standard 450nm leds.
I also found the raw led phosphor powders on aliexpress (just one vendor, and exclusively yellow, green and red) but that stuff is EXPENSIVE. Jesus christ. Think 100 euro for 10g of each powder. Standard nail polish fluorescent pigment is of course cheap as dirt.
« Last Edit: May 05, 2026, 10:51:22 AM by Laurens » Logged
Re: UVA pumped LEDs? « Reply #6 on: June 02, 2026, 01:48:01 AM » Author: Medved
These Toshiba look to me like a mixture of UVA and standard blue pumped LEDs (you can clearly see both peaks in the spectrum), my guess either alternating UV/blue components on the stripe, or each of them being actually a two or three die component, with one (or more) UV and one (or more) blue in the package.
And for the powder cost: 10g is in fact quite a HUGE amount of things like active phosphor dye, for normal DIY project you will need way less than a gram per project, unless you are doing something really big.
What makes these things expensive is the handling cost: These things tend to get very messy very quickly when spilled (you can not clean them out of anything it touches and it is the heck visible there), even when assuming they aren't toxic (beside being fine powder), so needs to be handled very carefuly. And that adds quite a lot of labor time to handle each individual package, regardless how much material is in it (if 10g cost 100Euro because of this, a 100g package would cost no more than 20 Euro; but for a DIY when 10g is a lot, 100g quantity becomes really useless).
Re: UVA pumped LEDs? « Reply #7 on: June 02, 2026, 03:24:04 AM » Author: dor123
Looks more like violet 405nm pumped white LEDs.
Re: UVA pumped LEDs? « Reply #8 on: June 02, 2026, 03:52:31 PM » Author: James
Actually these Seoul Semiconductor Sunlike LEDs are still blue pumped.  But they add a second violet chip to fill in the shorter wavelength part of the spectrum normally present in sunlight and traditional lamps which is missing in most LEDs.  The result is a big improvement in metamerism index and a crisper light that causes tge same degree of fluorescence from illuminated materials as present in other light sources.  There is some slight stimulation of the phosphors by the violet chips in addition to the blue.
Laurens
Re: UVA pumped LEDs? « Reply #9 on: June 03, 2026, 01:58:08 AM » Author: Laurens
Correct, not UV pumped. But it is another way to get the entire visible spectrum.
I've ordered some of the Toshiba/Seoul LED strips and chips from Aliexpress. A huge gamble (at best aliexpress semiconductors are a 50/50 gamble real/fake), however there are people on the internet who have claimed they are the real deal. They weren't cheap. The vendor supplies the spectrograms with the advertisement which is hopeful.
I'll post the spectrum pictures here once i receive them in 2 weeks or so. If they are legit, i'll post the links. Cost was 20 euro for a 120 led strip (iirc i bought the 2700 + 5500k one so you can mix your own color temperature), and 2x 4,50 for 20 2700k and 20 4000k SMD LEDs you could theoretically solder into any random ice cream cone LED lamp.
Lipstickquid
Re: UVA pumped LEDs? « Reply #10 on: June 06, 2026, 06:00:49 AM » Author: Lipstickquid
I haven't got any violet pumped LEDs myself but if I were going to spend that kind of money on an LED bulb, I would probably buy the Sunsy Shine ones.
But at $25-75 a bulb for quality violet pumped bulbs, I will continue to use real halogens for their even better SPD. Though the 4000K-5700K violet pumped LEDs are quite compelling.
I actually just wrote a super long post on reddit about violet pumped LEDs a couple weeks ago with the same name as here. Idk if linking to reddit is allowed here though.
The main differences between violet and blue pumps is the inclusion of violet(not UV) light which causes fluorescence in a lot more materials, particularly those with optical brightening agents(OBA) so white fabrics and paper will look better. Real incandescents or halogens have enough violet to do this as well. The white rendering differentiates them from even >95 CRI blue pumps which simply dont go far enough into violet to cause fluorescence, making stuff that looks crisp and vivid under incan, halogen or violet pumped LED look comparatively dull.
Their SPD is also fuller and smoother since they use broad spectrum red, green and blue phosphors. No big spikes from a blue pump, no cyan gap and usually a lot of red.
Laurens
Re: UVA pumped LEDs? « Reply #11 on: June 06, 2026, 09:56:51 AM » Author: Laurens
If i'm not mistaken, the Seoul leds i ordered are the ones used in the Sunsy lamps that are also available on Aliexpress. But we will find that out in one or two weeks time when i get them.
The individual leds are fairly cheap. The strip is expensive but if it is legit, for 120 leds of 2 color temperatures i am not too worried about spending that money. I want strip because of the diffuse lighting i need. The separate leds i can always put into any random ice cream cone LED lamp that costs like 2,50.
Lipstickquid
Re: UVA pumped LEDs? « Reply #12 on: June 06, 2026, 10:05:01 AM » Author: Lipstickquid
Ive seen tests of the aliexpress ones with the Seoul Sunlike and they're apparently good but idk if i would actually buy off alixpress to save $5. The guy who bought them for $20 recently tested them but idk how well they hold up. Idk about warranty either.
From what i know, Yuji's Sunwave violet pump are their own thing and may be double pumped. I dont remember. Soraa has their own too. Not sure what Waveform Absolute uses tbh. I think basically everything else violet pumped is Seoul Sunlike.
Laurens
Re: UVA pumped LEDs? « Reply #13 on: June 09, 2026, 02:10:45 PM » Author: Laurens
It's not as much saving $5, it's more the almost complete unavailability of that stuff on the european market.
I simply cannot buy those lamps or separate leds here. I found a german shop that does sell some kind of rectangular circuit boards in single piece numbers, but the shipping cost is almost as much as the cost of the entire strip itself from china. The issue with the german shop is that they did not have *both* 2700k and 4000 or 5500k in stock (i forgot which one). They can supply both, but not right now, and if i want to order in advance, i'm stuck with a minimum order quality of many dozens of boards, or thousands of LEDs.
Anyway, i got them. Preliminary spectrum pics of the LED strip (need to set it up a bit better, and run the strip from 12v and have it at a bit more distance rather than 9v and right on top of the little garden spectrometer)
First picture: 5500k
Second picture: 2700k.
It appears to be the real deal. The spectrum does not drup until below 650nm, and as opposed to conventional LEDs there is still emitted power above the 450nm pump diode emission. Whether this is a separate LED chip or not, i don't know. I think it has to be, because you cannot upconvert from 450nm to 420nm with phosphors.
The spectrum is somewhat bumpy but this may be caused by the 'toy' spectrometer i have.
I have to test the loose LEDs separately because they need to be on some sort of board since they're SMD.
This is where i bought them: https://nl.aliexpress.com/item/1005012232803294.html. Please note: i bought the LED strip for €22,50 - it now appears on the listing as €30. Sadly that is a bit excessive imho. I guess i'll wait a few years until this stuff becomes available for reasonable prices in the EU...
« Last Edit: June 09, 2026, 02:20:38 PM by Laurens » Logged
Lipstickquid
Re: UVA pumped LEDs? « Reply #14 on: June 10, 2026, 07:10:23 AM » Author: Lipstickquid
Those spectra look normal for a violet pump to me. The lumps are the individual red, green and blue phosphors in the triphosphor blend. Lumpy is fine tbh. Spiky is generally bad.
I dont think those are double pumped but apparently double pumped LEDs do exist.
