Author Topic: Have you’ve had an LED bulb go purple?  (Read 13807 times)
Lightingeye60
Have you’ve had an LED bulb go purple? « on: May 06, 2026, 11:09:51 AM » Author: Lightingeye60
I know this is a widespread failure mode with street lights. I’ve seen some older Cree bulbs go purple (bulbs were all seen in public and all the ones I’ve seen were the first generation models), but on this site I’ve been seeing posts about the 4-flows also doing it.
I haven’t had any LED bulb go purple from my experience. Most of the purple lights I see are LED street lights or parking lot lights. I’m wondering if you yourself have ever had one of your household LED bulbs turn purple. Do they all go purple if one does like the street lights do? I know if one street light goes purple if the others are part of the same batch those go purple too.
Laurens
Re: Have you’ve had an LED bulb go purple? « Reply #1 on: May 06, 2026, 12:21:18 PM » Author: Laurens
Conventional home use led lamps don't go purple.
I have seen some 6500k filament led lamps shifting to purple at the DIY store near me. But this is only a faint effect, with the lamps already having reached their specified life span. The 2700k ones don't do it, and it's also only 2 out of around 40 lamps on display.
Multisubject
Re: Have you’ve had an LED bulb go purple? « Reply #2 on: May 06, 2026, 01:12:31 PM » Author: Multisubject
https://www.lighting-gallery.net/index.php?topic=18703.0
It seems some older low quality lamps do this, but not nearly as often as street lamps do it seems
Lightingeye60
Re: Have you’ve had an LED bulb go purple? « Reply #3 on: May 06, 2026, 02:37:02 PM » Author: Lightingeye60
I’ve mostly seen it on early Cree models. No other brand of screw in LED seems to go purple. Several parking lot LED lights seem to go purple at the same rate as the Autobahn street light.
