Author Topic: Interesting Mitsubishi Lighting Technical Document from 1983  (Read 3062 times)
UChBXesrxSalDTp79uMtfDvA
Interesting Mitsubishi Lighting Technical Document from 1983 « on: May 15, 2026, 12:10:49 AM » Author: WorldwideHIDCollectorUSA
While doing some research on the lighting used in Japan, I have discovered this interesting technical report that discusses the characteristics of Mitsubishi’s 90 CRI BOC quartz metal halide lamps, deluxe high pressure sodium retrofit lamps, and energy saving mercury vapor lamps from about 1983. If you can’t understand the Japanese, you can use Google Translate to reveal some interesting information:
https://www.giho.mitsubishielectric.co.jp/giho/pdf/1983/8302.pdf
