Author Topic: Pure Sine Wave Travel Converter for European Collectors of North American Lights  (Read 8590 times)
UChBXesrxSalDTp79uMtfDvA
Pure Sine Wave Travel Converter for European Collectors of North American Lights « on: July 02, 2026, 06:17:34 PM » Author: WorldwideHIDCollectorUSA
While browsing on the internet for some voltage converters and transformers, I have happened to discover some 2000W pure sine wave voltage converters marketed to North American travelers that seemingly convert AC frequency from 50Hz to 60Hz. I am thinking that they might be beneficial for collectors who live in 50Hz countries that collect North American magnetically ballasted fluorescent and HID fixtures and want to use the original ballasts. From what I have researched, Epicka is one of those manufacturers that seemingly manufactures these voltage and frequency converters.
Here are some links that you can use to learn more about them:
https://www.epickatech.com/blogs/user-manual/voltage-converter-user-manual
https://www.epickatech.com/blogs/user-manual/voltage-converter-device-compatibility-list
https://www.epickatech.com/products/voltage-converter
https://www.ebay.com/itm/397951694004
So far, I have not tested one of these units yet.
In my research, I have not found evidence of voltage converters that are marketed toward 50Hz markets that convert 60Hz to 50Hz as I would love to find ways to operate 50Hz lighting without needing to buy an AC to DC power supply to run a 50Hz pure sine wave inverter or import a portable power station intended for a 50Hz country.
« Last Edit: July 02, 2026, 06:35:32 PM by WorldwideHIDCollectorUSA » Logged
Re: Pure Sine Wave Travel Converter for European Collectors of North American Lights « Reply #1 on: July 04, 2026, 03:57:28 AM » Author: RRK
Interesting to do a teardown and see how many corners they have cut to fit a 1700VA converter into a such tight space, with all sockets, extra USB charger, and all regulatory necessary filtration. And just for $90 retail. Though, I think it is doable with modern power transistors and magnetics. Today's server power supplies at 12 and 48V are even more compact for such a power. But are not $90 of course )
This solution competes with using a surplus dual conversion UPS which often can be set to do 50 -> 60Hz (or even 60 ->50)conversion, even with dead old batteries. These UPS can be found just for scrap metal value, but for sure are much more bulky than this gadget.
« Last Edit: July 04, 2026, 04:01:40 AM by RRK » Logged
