Burrito
| Anyone know where I can find some clear 175 watt mercury vapor lamps? I want to try to find a Westinghouse Lifeguard version.
Going on 6 years and counting. RMS Titanic went down 114 years ago. Works at The Home Depot store # 4412 and proud of it!!!
Burrito
| Perhaps! I don't really trust Etsy tho. It's full of scams and stuff :/
If you want to build a stash of burner lamps, I recommend purchasing these lamps from light bulb depot: https://lightbulbdepot.com/products/details/di/mercury-vapor-h39kb175-clear/01038A/?subId%5B%5D=269&dept%5B%5D=ED28&sortBy=default&pageNum=1&itemsPerPage=10&offset=2&returnPage=products%252F#nogoYou will probably need to be patient for a while to find clear Westy Lifeguard lamps these days.
Burrito
| I know, that's why I want any 175 watt clear mercury lamp.
| Good luck in your search.
Econolite03
Matthew E.
Check out Mercari. I have purchased a number of vintage mercury lamps from here before at much better pricing than eBay. See Here
All Hail the GE M-400
Not a Westy but a USA made Philips : https://www.ebay.com/itm/185853188752
Burrito
| Hm, may get this one you just linked
| It would look excellent in your NOS Joslyn NEMA fixture!!
Burrito
| I agree. Will be my first clear mercury lamp too.
Update: found this Westy Lifeguard on eBay: https://ebay.io/m/9KYtBY
| I'd personally hold out for a BT-28 lamp if you plan to install it inside your Joslyn, ideally a NOS one. It's probably the most era appropriate as most mercury lamps were BT-28 back then.
Burrito
| I did get an NOS GE Form 201 unit pack and it comes with a clear mercury lamp.
