Author Topic: ANSI Ballast Codes: What's with the "E"?  (Read 20931 times)
Multisubject
ANSI Ballast Codes: What's with the "E"? « on: July 15, 2026, 09:01:22 PM » Author: Multisubject
Almost all americal HID ballasts have ANSI ballast codes on them, whether it be M59 for 400W MH, H38 for 100W MV, or S55 for 150W HPS among others of course. But on the etch of many lamps (especially MH and HPS) I see a lot of them with an "E" suffix, like M59E or S51E or whatever. What's it mean?
Re: ANSI Ballast Codes: What's with the "E"? « Reply #1 on: July 15, 2026, 11:34:57 PM » Author: wide-lite 1000
 Means the lamp is for enclosed fixtures only .
Multisubject
Re: ANSI Ballast Codes: What's with the "E"? « Reply #2 on: July 16, 2026, 10:03:29 AM » Author: Multisubject
Really? I would have thought that would be in the part number (like LU100E or something as opposed to the ANSI code). Also aren't pretty much all HPS lamps rated for exposed use?
Re: ANSI Ballast Codes: What's with the "E"? « Reply #3 on: July 16, 2026, 12:26:40 PM » Author: joseph_125
That's what I thought as well. The E denoting enclosed lamps was in the lamp part number and not the ballast code.
Re: ANSI Ballast Codes: What's with the "E"? « Reply #4 on: July 17, 2026, 06:17:19 AM » Author: Medved
Isn't it so when the ballast drives the lamp in a way that may make the explosion prevention features ineffective?
