Author Topic: Some questions about 120V ballasts (reputable brands? Magnetic and electronic?)  (Read 2310 times)
Hertz2006
Some questions about 120V ballasts (reputable brands? Magnetic and electronic?) « on: August 06, 2026, 06:20:58 PM » Author: Hertz2006
Hi All,
I bought an old security light fixture (the old classic die-cast aluminum sort that you see on garages/barns) that I believe used to be mercury vapor, but it is so old that the informations on the bulb are gone and the transformer is rusted. Probably the old owner took it down because it stopped working, but I got the fixture for $10 off of marketplace so I figured it would need new hardware anyways.
I'm considering keeping the fixture as MV and putting it up in my yard using a metal halide ballast, as I understand that you can run MV lamps off of the next-size-down probe-start MH ballasts. I may also just convert to HPS since I have some 70W HPS lamps already.
Regardless, I am wondering: What is a good, reputable brand for ballasts? I would like to buy a variety of 120V ballasts all at once to have in inventory, and one potential website selling ballasts sells "Keystone" ballasts. What are some brands that you all prefer for 120V ballasts?
In the search for ballasts I am also seeing the distinction between magnetic and electronic ballasts being made from potential vendors. What are the key differences between magnetic and electronic as it pertains to reliability, and which do you all prefer?
I live in Upstate NY, just a stone's throw from Schenectady, The Electric City. I am particularly interested in GE Lighting.
I am new to the hobby so please excuse my deluge of questions. :)
Multisubject
Re: Some questions about 120V ballasts (reputable brands? Magnetic and electronic?) « Reply #1 on: August 06, 2026, 07:18:55 PM » Author: Multisubject
MV Bulb -> MH Ballast compatibilities are not as simple as one wattage size lower. For 175W, 250W, 400W, and 1000W* lamps are completely compatible with MH ballasts of the same wattage. For wattages below 175W, it becomes more complicated, but those are rarely used for yard lights (175W and 250W are most common as far as I have seen). If you are considering using 100W MV or below then we can cross that bridge when we get there, in my opinion it's more effort than it's worth (I bought a 100W MV lamp and running it is a pain). HPS lamps are very uncomplicated in this regard as their ballasts are still widely available. 70W should be just fine if you decide to go the HPS route.
As far as brands go I am not very familiar with that, I am sure some are better than others but I am not sure which ones.
For HID lamps, almost all ballasts are magnetic, meaning resembling a transformer instead of a circuit board. Electronic ballasts start to pop up more often in wattages below 100W, and they are probably more expensive and not worth it. Reliability with these I would assume is much more variable, though I don't have anyu experience with them. Also never heard of them even existing for probe start lamps, though I could be wrong.
What is your goal with having multiple ballasts on hand? Just wondering cause if you want to be able to just run some lamps every once in a while I have a ~perfect solution for that.
Also uploading a picture of the lamp and fixture will help determine what it would have been, these types of lamps are very easily identifiable usually.
Hertz2006
Re: Some questions about 120V ballasts (reputable brands? Magnetic and electronic?) « Reply #2 on: August 07, 2026, 04:17:24 PM » Author: Hertz2006
Quote
I wasn't aware that 175W and 250W are more typical, but makes sense now that you mention it as most of what I see available are 175W fixtures, including the one I have. My interest in the lower wattage MV bulb/ballast combos is partially curiosity to tinker and partially desire to keep light output low to avoid annoying neighbors as well as allow more fixtures. For example, my porch light is a 35W HPS wallpack so it illuminates the porch nicely but the front yard and driveway could be better illuminated by a post light in my front yard that currently does not work. Since it needs rewiring, I think it would be a fun project to attempt to convert that light from an incandescent fixture to a low-wattage MV or HPS fixture.
Quote
Sounds to me like magnetic is the way to go in cost and reliability, then - I don't see a circuit board outliving a transformer.
Quote
Desire to have spare ballasts on hand in case a replacement is needed for a lamp I have in service, and to have some ballasts for tinkering around with converting fixtures to HID for instance
Multisubject
Re: Some questions about 120V ballasts (reputable brands? Magnetic and electronic?) « Reply #3 on: August 07, 2026, 05:39:30 PM » Author: Multisubject
I think that post light conversion project would be cool. Indeed 175W can be kind of a lot for a post light. I think for this application a 50W HPS, 70W MH, or 100W MV, which are all roughly equivalent in brightness. They are decently brighter than your 35W HPS porch light but a good step below 175W MV. Now to choose which one...
50W HPS:
- Light will obviously match the color of your HPS porch light.
- Ballasts are easy to find.
- Bulbs commonly available in medium base so you won't have to change the socket in your post light.
70W MH:
- White light, which may or may not be desirable for you.
- Ballasts are also very easy to find.
- Bulbs pretty much only available in medium base, again no need to change the socket.
100W MV:
- White-ish light if coated, or if clear a teal that will contrast the HPS porch light which may or may not be desirable (I think it'd be cool).
- Ballasts are very difficult to find, and when you do find them they invariably aren't 120V. You can use a 70W MH ballast which will underdrive slightly, or a 100W MH ballast which will overdrive slightly.
- Commonly available in mogul base, though you can shell out some extra to get an A23 shape one with a medium base. Depending on your fixture you may or may not have the necessary space to fit a mogul socket.
You mentioned having 70W HPS lamps on hand, they are roughly as bright as a 175W MV but if you want it to be real bright that is another option. They are also available in medium base and ballasts are of course easy to find. No right or wrong answer to be honest, these are just my suggestions
