Author Topic: Selecting proper in-line fuse rating for vintage ballast?  (Read 29634 times)
Hertz2006
Selecting proper in-line fuse rating for vintage ballast? « on: September 08, 2026, 02:25:21 PM » Author: Hertz2006
Hi all,
I tried to rewire a Universal 449-RS-WS dual 32W + 22W circline ballast from 1963, but while inside I hit some component (gallery post). Any clue what that component I hit is? The ballast still works, so I intend to use it, but to protect both my home and the ballast I'm going to add an in-line fuse.
The ballast is rated 118 volts and 0.95 amps. In testing, my Kill-A-Watt meter says the ballast pulls around 0.9 amps. A previous discussion here suggests 1- or 1.5-amp slow-blow fuses for the sort of use-case I am after. With a ballast rated for 0.95 amps, do you think a 1-amp slow blow fuse is likely to cause nuisance trips? I am thinking that the best approach is probably to buy both 1- and 1.5-amp fuses and if I get nuisance tripping from the 1-amp, size up to 1.5-amp.
In general, what method is best for calculating the appropriate amperage rating for fusing a ballasted fixture (fluorescent or HID)?
« Last Edit: September 08, 2026, 02:28:38 PM by Hertz2006 » Logged
I live in Upstate NY, just a stone's throw from Schenectady, The Electric City. I am particularly interested in GE Lighting.
I am new to the hobby so please excuse my deluge of questions. :)
Multisubject
Re: Selecting proper in-line fuse rating for vintage ballast? « Reply #1 on: September 08, 2026, 02:30:43 PM » Author: Multisubject
I would suggest a 1.5A fuse. If there's any significant fault then it will blow. 1.5A is not a whole lot of current in the grand scheme of things. If you do a 1A slow blow you probably won't have problems, but I just wouldn't do that.
Hertz2006
Re: Selecting proper in-line fuse rating for vintage ballast? « Reply #2 on: September 09, 2026, 01:25:24 PM » Author: Hertz2006
Do you think that slow blow is not ideal for this use-case?
Multisubject
Re: Selecting proper in-line fuse rating for vintage ballast? « Reply #3 on: September 09, 2026, 01:33:54 PM » Author: Multisubject
If you choose 1A, I would definitely do slow blow. But for 1.5A you could choose whatever, not much of a difference. Either will blow in a short.
Re: Selecting proper in-line fuse rating for vintage ballast? « Reply #4 on: September 12, 2026, 11:17:13 AM » Author: joseph_125
Some ballasts listed a recommended fuse size in the datasheet but the documentation is getting harder and harder to find online now.
Generally for 2xF40T12 ballasts (0.80A current draw) I fuse them at 1A which seems to work fine. Since your ballast has a bit higher current draw, I would probably opt for 1.25A or 1.5A
Re: Selecting proper in-line fuse rating for vintage ballast? « Reply #5 on: September 21, 2026, 12:27:57 AM » Author: icefoglights
I'm going with a 1.5A for my HF100 which is rated at 0.85A.  I'm sizing my fuse to be 20% above the ballast rating (1.06A), rounding up to the nearest available fast acting fuse size I could find.  My second choice would have been 1A slow blow.
« Last Edit: September 22, 2026, 03:02:39 AM by icefoglights » Logged
