Author Topic: How to make HPS bulb last longer  (Read 6573 times)
NeXe Lights
How to make HPS bulb last longer « on: September 29, 2026, 10:22:43 PM » Author: NeXe Lights
Recently, I was wonder if there is a way to increase the lifespan of high pressure sodium bulbs. Is this possible in anyway? If so, would using, for example, a 310W HPS bulb on a 250W HPS ballast increase lifespan of the bulb when run dusk to dawn?
Re: How to make HPS bulb last longer « Reply #1 on: September 30, 2026, 01:48:14 AM » Author: RRK
Usually, you can prolong the life of a HID lamp by reducing the power to about 2/3 of nominal. But in the most cases, until you run some special type of lamp like tin type or unsaturated metal halide for example, you quickly end up with a bad color. In the case of HPS lamps, CRI drops considerably already over nominal line voltage variations!
NeXe Lights
Re: How to make HPS bulb last longer « Reply #2 on: September 30, 2026, 06:10:30 PM » Author: NeXe Lights
So would operating a 310W HPS bulb on a 250W HPS ballast increase lifespan? By how much? Color and lumen output is not a concern.
Laurens
Re: How to make HPS bulb last longer « Reply #3 on: October 01, 2026, 01:04:06 AM » Author: Laurens
I have a Dali dimmable 70w SON sitting around. Been meaning to hook it up for a while now, i'll report when i do, it can dim to 50% afaik.
Buuuuuuuut
HPS lasts extremely long as it is. It is not really something i would worry about.
Re: How to make HPS bulb last longer « Reply #4 on: October 01, 2026, 11:10:26 PM » Author: RRK
By how much?
I doubt anyone can tell you exactly. Not even a lamp manufacturer, until a series of lifetime tests were run, which is very time-consuming (obviously) and expensive.
Generally, physical/chemical processes that limit the lamp lifetime, arctube corrosion, sodium migration, electrode sputtering and so, should follow Arrhenius law, meaning that decreasing of the temperature will slow down them. But, decreasing vapor pressure will promote sputtering. Also, decreasing electrode temperature will decrease electron emission, and in the end, increase cathode drop, ion bombardment, and finally, sputtering.
Lifetime vs power curve is well-known for simple tungsten incandescents, but things are much more complicated in discharge lamps.
« Last Edit: October 02, 2026, 02:07:49 AM by RRK » Logged
NeXe Lights
Re: How to make HPS bulb last longer « Reply #5 on: October 04, 2026, 10:56:42 AM » Author: NeXe Lights
Got it. Thanks for all the information.
AsXSn
Insulator, electrotechnic and HID lamps lover
UCop_Ku87f88E6twttI4ZIdg asxsn2003
Re: How to make HPS bulb last longer « Reply #6 on: October 06, 2026, 05:00:13 PM » Author: AsXSn
Some streets in my town were lit by Philips SGS101 50W, but these fixtures have run 70W lamps instead proper 50W causing most lamps in these lasting more than 10 years.
Worse things starts happen with underdriven MHs especially ceramic ones, salts and halides in lower temperatures can cause faster arc tube walls erosion
« Last Edit: October 06, 2026, 05:03:15 PM by AsXSn » Logged
