Author Topic: Soft Start Device for Incandescent Bulbs  (Read 3087 times)
NeXe Lights
Soft Start Device for Incandescent Bulbs « on: September 30, 2026, 06:12:23 PM » Author: NeXe Lights
Recently, I've been wanting to increase the lifespan of the incandescent bulbs I use, and I know one way to do this is with a soft start device to limit the inrush current on an incandescent bulb. Does anyone know where to find these? I could not find any such products online.
LightsoftheWest
SRP for life.
streetlightian
Re: Soft Start Device for Incandescent Bulbs « Reply #1 on: September 30, 2026, 07:39:20 PM » Author: LightsoftheWest
You could also try finding some that are rated for 130V operation. Since they'd be slightly under driven, the lifespan would increase accordingly.
LG's North American luminaire identification specialist
NeXe Lights
Re: Soft Start Device for Incandescent Bulbs « Reply #2 on: September 30, 2026, 08:22:26 PM » Author: NeXe Lights
I know I could, but I already have a decent-sized stock of 120V bulbs collected over time from my local ReStore. Therefore, I'd rather spend less money on a few soft-start devices than replace nearly my entire stock of bulbs with 130V bulbs.
« Last Edit: September 30, 2026, 08:25:55 PM by NeXe Lights » Logged
Patrick
Webmaster
LightingGallery
Re: Soft Start Device for Incandescent Bulbs « Reply #3 on: September 30, 2026, 11:11:42 PM » Author: Patrick
How effective are such devices?  I'd simply use a dimmer switch.
Patrick C., Administrator
Re: Soft Start Device for Incandescent Bulbs « Reply #4 on: September 30, 2026, 11:47:11 PM » Author: joseph_125
I'd second just using a dimmer switch. A lot of newer dimmers are programmed to soft start lamps, even if turned on at the highest setting.
Plus one of the things I like the best about incandescent is how they gradually lower in colour temperature as they are dimmed. Some LEDs attempt to emulate this behavior but at very low output incandescent is still the best.
Re: Soft Start Device for Incandescent Bulbs « Reply #5 on: September 30, 2026, 11:53:17 PM » Author: wide-lite 1000
 Quick snoop on eBay found these : https://www.ebay.com/itm/158358422909  https://www.ebay.com/itm/137662182031
SoxFtw
Re: Soft Start Device for Incandescent Bulbs « Reply #6 on: October 01, 2026, 02:53:47 AM » Author: SoxFtw
As Patrick said, a dimmer is usually adequate. Or you could use a diode for three seconds then short across it, but unless you're working at a large wattage, it probably wouldn't matter too much.
Survivor of photokeratitis :(
👉KeepAndroidOpen.org👈
