Author Topic: 22w programmed start circline ballast  (Read 42 times)
lightinggalleryuser33450
22w programmed start circline ballast « on: October 22, 2026, 09:59:22 PM » Author: lightinggalleryuser33450
i want a programmed start electronic ballast for 22w FC8T9 circline lamps. does this exist? all i can find is rapid start, preheat, and instant start. but not programmed start
UChBXesrxSalDTp79uMtfDvA
Re: 22w programmed start circline ballast « Reply #1 on: October 22, 2026, 10:13:48 PM » Author: WorldwideHIDCollectorUSA
If you do want to go the programmed start route for 22W T9 circline fluorescent lamps, I think a programmed start ballast for 9 inch 18W PL-L lamps is a good place to start since I have researched that 9 inch 18W PL-L lamps have somewhat similar characteristics compared to 22W T9 circline lamps.
An example of a programmed start ballast that should work for your needs is a Fulham Racehorse RHA-226-C ballast as I do see that it is listed for a single 9 inch 18W PL-L lamp.
See here:
https://ebay.io/m/dCXQO2
