Author Topic: Best way to simulate mercury vapour lighting?  (Read 151 times)
Azaran
Best way to simulate mercury vapour lighting? « on: November 16, 2026, 09:14:21 PM » Author: Azaran
I've always wanted to simulate the greenish tinge of mercury vapour indoors, using safer alternatives / LED's. I had played around with painting clear filament 5000k LED bulbs with turquoise and green glass paint, but they go from not green enough, to too much, and it's almost impossible to layer the paint properly (though I did end up with some nice turquoise bulbs). The best I've been able to come up with is using color changing filament LED's, I'm able to get a glow that's nearly indistinguishable from real mercury vapour. I was wondering if anyone had found even better methods to achieve this?
 :mv:
Laurens
Re: Best way to simulate mercury vapour lighting? « Reply #1 on: Today at 01:50:56 AM » Author: Laurens
The dominant spectrum lines in mercury vapor are 578, 546, 435 and 404nm. LEDs roughly in this range are available on the market, being 5nm off is not very important. Using these will get you the low pressure discharge spectrum.
If you use a 6000k lowest quality possible LED instead of the 435 blue (you *want* that ugly 440nm blue pump diode spike to remain), you will approximate the high pressure spectrum, since the high pressure discharge has a very small amount of continuous spectrum. 405nm is available as near-UV led. 540nm is also a standard led and i see 580nm too. And of course 440nm is very common.
Give each their own adjustable current source and experiment till you have the right color.
Let us know your experiences.
Mercury vapor lamps are pretty safe, though. They don't fail in an explosive way. They do run very VERY hot of course - hot enough to burn stuff, but that's no different from high power incandescents and especially halogens.
« Last Edit: Today at 01:55:41 AM by Laurens » Logged
Re: Best way to simulate mercury vapour lighting? « Reply #2 on: Today at 02:12:45 AM » Author: RRK
Why not to get The Real Deal (tm) - some small 50W (or 80W) mercurys, deluxe or clear, whatever you prefer. Perfectly home friendly and small. )
You do not state your region, for 230V ballasting is very simple, as well.
You can also play with self-ballasted lamps, but take care they run *really* hot, no joke, and are fussy about their orientation.
« Last Edit: Today at 02:14:57 AM by RRK » Logged
SoxFtw
Re: Best way to simulate mercury vapour lighting? « Reply #3 on: Today at 05:45:16 AM » Author: SoxFtw
This may be a region-specific issue, although in some place clear MV lamps can be quite hard to obtain... but deluxe? No problem. Note, two of my coated MV lamps, both appear as a neutral/cool white with a mild tint, not as prominent as in your picture. That being said, I've heard clear lamps have a cyan-ish tint?
Looking at some uploaded pics, @Azaran is in north america which uses standard 110/120V so finding a self-ballasted lamp may not be as easy as in 240V lands but it's possible and they absolutely do exist, and you can even find some on amazon.com for around $30 designed for use with reptiles.
Survivor of photokeratitis :(
👉KeepAndroidOpen.org👈
Laurens
Re: Best way to simulate mercury vapour lighting? « Reply #4 on: Today at 10:07:20 AM » Author: Laurens
Clear ones are exceptionally hard to find in many countries. I got mine (Iwasaki H50) from the UK. The store where i bought a few had 40 in stock for less than 10 pounds a piece. However, just a day after i posted the link here, the entire stock was gone.
Normal coated 80w ones are relatively(!) easy to get. Currently DBL Verlichting has a few in stock. But the color of those ones (when fresh) actually looks pretty nicely white.
Azaran
Re: Best way to simulate mercury vapour lighting? « Reply #5 on: Today at 10:51:45 AM » Author: Azaran
Hmmm that could be an option, I might look up how to make my own like that.
They do sell mercury vapour reptile lamps on Amazon I could get, but some people say they're colour corrected (i.e fully white and indistinguishable from white LED), and since they run very hot I'd be concerned about them melting my plastic apartment fixtures
SoxFtw
Re: Best way to simulate mercury vapour lighting? « Reply #6 on: Today at 11:03:40 AM » Author: SoxFtw
WOW! So it's not just me... lol, I thought it was just my country.
@Azaran look at it this way, an 80W or 100W MV lamp physically cannot get hotter than an equal-wattage incandescent. There is no way for a 100W MV lamp to emit more heat than a 100W incandescent which is actually more efficient in heating things up than MV lamps; therefore if it can tolerate a 100W incandescent, it can tolerate a 100W MV. If your fixture has a plastic cover and a metal body, removing the cover should get the job done.
I haven't bought any heat lamps myself (quite expensive), but I highly doubt the color correction is better than a standard DX lamp which too looks rather similar to an LED. And if you don't have any mercury vapor lamps of your own yet, it's a good start. Most of the images seem to feature uncoated lamps though--maybe there's a phosphor-coated reflector?
