Author Topic: How to make a PG17 Ballast Louder?  (Read 369 times)
Burrito
McGraw Edison Rotoshields
How to make a PG17 Ballast Louder? « on: November 17, 2026, 02:08:58 PM » Author: Burrito
lol, this is something I want to try. I have a Advance sound rated D ballast that is sort of noisy up close, but I want to make it a lot more audible in my room, how do I go about doing that?
Going on 6 years and counting. RMS Titanic went down 114 years ago. Works at The Home Depot store # 4412 and proud of it!!!
Patrick
Webmaster
LightingGallery
Re: How to make a PG17 Ballast Louder? « Reply #1 on: November 17, 2026, 06:28:00 PM » Author: Patrick
Surprisingly a simple metal wire caused this normally quiet light fixture to buzz so loudly you could hear it down the street.  Sadly it contributed to it being replaced.  I've often found the noise level of open ballasts to be affected by the fixture and how it's mounted due to the alternating magnetic field and vibrations, but much less so with potted ballasts.  Besides a microphone there's presumably some way to situated it that'd amplify the noise.  I'd never want to do anything to boost the noise myself.  While I don't mind a gentle hum, I generally prefer my ballasts to be as close to silent as possible.
Patrick C., Administrator
Burrito
Re: How to make a PG17 Ballast Louder? « Reply #2 on: November 17, 2026, 06:33:45 PM » Author: Burrito
Interesting, that video you linked sounded like when you rattle sheet metal lol. I am trying to see if I can get this PG17 ballast to sound louder for room ambience really. It is a potted ballast as well.
Re: How to make a PG17 Ballast Louder? « Reply #3 on: November 17, 2026, 08:00:22 PM » Author: joseph_125
A loosely mounted piece of ferrous metal near the ballast will tend to cause a louder hum as the magnetic field will cause the metal itself to vibrate. You could try adding in a fluorescent ballast line filter, which contain inductors themselves which might also hum.
Another trick if this is a two lamp fixture is to replace the ballast with two single lamp ballasts, that's generally louder than one ballast.
Aside from the fixtures in my garage, I also generally prefer my fluorescent lights to be fairly quiet, just a gentle hum if anything.
Burrito
Re: How to make a PG17 Ballast Louder? « Reply #4 on: November 17, 2026, 11:37:41 PM » Author: Burrito
I have tried small sheet metal parts, but it doesn't amplify the noise, I want to see if I can find something that truly will amplify the buzz.
