Author Topic: Are Philips Alto’s really that bad?  (Read 154 times)
Goodlighting2000
Are Philips Alto’s really that bad? « on: November 22, 2026, 05:47:26 PM » Author: Goodlighting2000
So many people on here used to say and still say that Philips Alto lamps frequently burn out early and some even said they kill ballasts, but is that really true? Are Philips Alto’s really that bad?
Econolite03
Matthew E.
Re: Are Philips Alto’s really that bad? « Reply #1 on: November 22, 2026, 06:34:48 PM » Author: Econolite03
The fluorescent tubes I can confirm sucked… go mercury starved very quickly. I wasn’t alive for the pre-Alto HPS stuff so someone else has to touch on that.
 :stirfl:
All Hail the GE M-400
Lightingeye60
Re: Are Philips Alto’s really that bad? « Reply #2 on: November 22, 2026, 06:52:02 PM » Author: Lightingeye60
The older Alto’s yes, they always went mercury starved (and they performed horribly when turned on and off constantly due to weak cathodes).
The energy saving and U-bend Alto’s especially suck. The Alto II’s didn’t go mercury starved as much but they didn’t perform well under frequent short use.
stillaintjeff24
Re: Are Philips Alto’s really that bad? « Reply #3 on: November 22, 2026, 07:13:48 PM » Author: stillaintjeff24
I have alto IIs and while one bulb did fail within a few months on a instant start ballast, the others on better ballasts look and perfect.
BT25
Vintage HID Collector
Re: Are Philips Alto’s really that bad? « Reply #4 on: November 22, 2026, 08:11:42 PM » Author: BT25
 :stirfl:
If you like reddish-yellow HPS, then Alto/Eco lamps are for you. 'Pre-enviro' HPS with the dreaded Hg were brighter, whiter and just pleasant to be around, but still not as good as a DX.
As to Alto/Eco fluorescents, they've always been 'mercury starved'...they came that way from the factory!!!
HID - Lighting with personality.
Econolite03
Matthew E.
Re: Are Philips Alto’s really that bad? « Reply #5 on: November 22, 2026, 08:55:51 PM » Author: Econolite03
@BT25: I’ve definitely noticed that. My early 1980s HPS lamps definitely have a “champagne” color, whereas the post-2001 lamps are a pronounced orange hue. The tubes… probably.
BT25
Re: Are Philips Alto’s really that bad? « Reply #6 on: Today at 08:29:37 AM » Author: BT25
@Econolite03 - Its the Hg content in the arc-tube. The thought back in the 90's was to make HPS and fluorescent lamp non toxic so the would pollute the environment...not a bad idea. But typical of government, they didn't cover all the bases with this requirement. Efficacy fell, along with color rendering to the point the became undesirable and were only used in the end, because that's all that was available...except for DX, which still had the dreaded Hg.
