Author Topic: Why didn’t the GE F34T12’s go mercury starved as much as other brands?  (Read 146 times)
Lightingeye60
Why didn’t the GE F34T12’s go mercury starved as much as other brands? « on: November 23, 2026, 06:19:43 PM » Author: Lightingeye60
Both the Sylvania Ecologic and Philips Alto F34T12’s were prone to going mercury starved early in their lifetime, but I haven’t seen it on nearly as many GE F34T12’s.
I’ve seen Sylvania Supersaver Ecologics and F34T12 Alto’s go mercury starved shortly after installation, but I’ve seen far less GE’s do the same. Is it possible that the GE F34’s had more mercury? Did GE find a way to actually make an F34T12 right in the sense that it’d usually stay bright over its lifetime? Even the Ecolux F34’s didn’t go mercury starved nearly as often. I’ve definitely seen mercury starved GE F34T12’s in my life, but it doesn’t seem as common. Same goes for F60 and F96 lamps. Places that relied only on Sylvania Supersaver Ecologic and Philips Alto F34T12’s often had some fixtures dimmer than others because they would keep going mercury starved.
The full mercury Sylvania Supersavers and the pre-Alto Philips F34’s didn't go mercury starved quite as much either.
In your experience, have you’ve seen many mercury starved GE F34T12 tubes?
« Last Edit: November 23, 2026, 06:55:11 PM by Lightingeye60 » Logged
Emersyn
Re: Why didn’t the GE F34T12’s go mercury starved as much as other brands? « Reply #1 on: November 23, 2026, 08:46:18 PM » Author: Emersyn
I have about 17 2021 GE F34CX41s and none of them have big mercury issues! They're really good on electronic ballasts!
Lightingeye60
Re: Why didn’t the GE F34T12’s go mercury starved as much as other brands? « Reply #2 on: November 23, 2026, 09:46:27 PM » Author: Lightingeye60
I’ve noticed that too. The GE T12’s don’t seem to suffer from the same major mercury starvation issue that affects the T8’s. It’s primarily the GE T8’s going mercury starved, not the GE T12’s. I’ve seen far less mercury starved GE T12’s compared to other brands.
The non-Ecologic Supersavers didn’t usually go mercury starved early, and they tended to last a while, and when they are mercury starved, they’ll usually heavily used with very heavy end blackening. The Ecologic versions, However, would go mercury starved quite frequently and that was a frequent failure with those. In my experience, I’ve seen far more Supersaver Ecologics fail mercury starved early than fail early from a cathode failure under normal conditions. The Sylvania’s weren’t quite as bad as the Philips energy saver Alto’s, though. Not all Sylvania Supersavers had the issue, the non-Ecologic ones often lasted their entire life before going mercury starved or burning out. Most mercury starved non-Ecologic Supersavers I’ve seen were very well used lamps with heavy end blackening.
Honestly, it’s not extremely common for a GE Ecolux T12 to go mercury starved. While it does happen, it happens far less often than a Sylvania or an energy saver Alto T12. The T8 Ecoluxes however, go mercury starved frequently. Philips F34’s were just utter garbage, they’d either burn out early or go mercury starved early. I’ve seen some Alto’s burn out very early as well, not even just mercury starved.
It seems quite common for all Sylvania T12’s to go mercury starved by the end of its life. Not sure if it’s something with the phosphor sylvania uses or what, but even the full wattage, full mercury ones would often go mercury starved at the end of their lifespans (usually when it already has end blackening), I’ve rarely seen full wattage, full mercury Sylvania tubes that went mercury starved prematurely. The Sylvania T12’s seem to actually be more prone to mercury starvation than their T8’s.
« Last Edit: November 23, 2026, 09:53:52 PM by Lightingeye60 » Logged
tigerelectronics
Long live fluorescent!
UCcObKY_XCMIZZOBNWn-PC4A
Re: Why didn’t the GE F34T12’s go mercury starved as much as other brands? « Reply #3 on: November 25, 2026, 10:10:17 AM » Author: tigerelectronics
34W tubes were never a thing here in Europe but I’ve seen some
People deliberately overdriving them to get impressive light output from them and they seem to handle abuse really well, I don’t know but it feels like they’re built to a better standard than one would initially expect
Fluorescent tube hoarder :P
