Author Topic: Worn out EYE SUNLUX lamp  (Read 7970 times)
imj
Worn out EYE SUNLUX lamp « on: May 16, 2011, 11:31:31 AM » Author: imj
http://www.youtube.com/watch?v=nuxq8a6RYzQ
Re: Worn out EYE SUNLUX lamp « Reply #1 on: June 16, 2011, 10:49:04 AM » Author: dor123
I encountered this phenomenon of flickering of HPS lamps before the sodium vapourises, with streetlights that had good HPS lamps, when i was a child in the 1990". Many HPS streetlights did this.
Today, i don't see this phenomenon anymore. Neither HPS lamp that i see turns on, don't do this.
Re: Worn out EYE SUNLUX lamp « Reply #2 on: June 17, 2011, 03:17:37 AM » Author: Ash
I sometimes see this in all types of SON fixtures
Do you use the type of starter that gives distinct flashes when restriking or that gives constant impulses at 50 HZ ?
Re: Worn out EYE SUNLUX lamp « Reply #3 on: June 17, 2011, 04:20:32 AM » Author: dor123
Ash: The starter is incorporated in this lamp as standard.
This lamp don't required an external ignitor.
All of the current european 70W HPS lamps with integral ignitor, have a glow starter, similar to the one of the fluorescents.
Re: Worn out EYE SUNLUX lamp « Reply #4 on: June 17, 2011, 01:36:53 PM » Author: Ash
Is this the Iwasaki with electronic starter inside ?
Re: Worn out EYE SUNLUX lamp « Reply #5 on: June 17, 2011, 01:50:43 PM » Author: dor123
Ash: Even that this lamp was made by Iwasaki Japan, this is your typical 70W HPS lamp with an internal glow starter.
You can see it operating behind the coating, before the lamp ignite.
As far as i know, Iwasaki lamps and most japanese lamps brands aren't imported to Israel. But i saw Toshiba fluorescents in an emergency fixture, and an Iwasaki lantern in Kibbutz Harel.
« Last Edit: June 17, 2011, 01:53:09 PM by dor123 » Logged
