Author Topic: Phillips F15 T8 CW PLus  (Read 8169 times)
Powell
Phillips F15 T8 CW PLus « on: June 14, 2011, 02:02:13 PM » Author: Powell
I got 2, unused at the GoodWill Thrift store for $2.00 US each. Boy are these bright!
http://www.ecat.lighting.philips.com/l/catalog/catalog.jsp?userLanguage=en&userCountry=us&catalogType=LP_PROF_ATG&_dyncharset=UTF-8&categoryid=LP_CF_F_T8RETA_EU_FA_US_LP_PROF_ATG&productid=927875603312_NA_US_LP_PROF_ATG&title=F15T8%20CW%20Plus%20ALTO&ctn=927875603312_NA
NNNN!
Powell
Re: Phillips F15 T8 CW PLus « Reply #1 on: June 14, 2011, 02:24:05 PM » Author: Powell
On the web it says 7500 hours at 3 hours per start, on the lamp cover it says 7500 hours at 6 hours per start. HMMMM !
NNNN!
Re: Phillips F15 T8 CW PLus « Reply #2 on: June 14, 2011, 05:51:24 PM » Author: sol
Powell, did you notice that the "base information" is that it a Green Base ? I suppose that according to Philips, the colour of the base makes the lamp, so to speak.  ;)
Powell
Re: Phillips F15 T8 CW PLus « Reply #3 on: June 14, 2011, 05:53:11 PM » Author: Powell
It's a green ended Alto! Is that what you mean. It has a date code but I am 15 miles away from the lamps.
Powell
NNNN!
Re: Phillips F15 T8 CW PLus « Reply #4 on: June 14, 2011, 06:03:58 PM » Author: sol
Powell, no, that is not what I meant. On the Philips web site, it lists the green end caps as one of the features of the bulb. As to say, 'our lamps are better than the competitor's because they have green caps.' I guess that according to Philips, good looks means a lot !  ;)
Powell
Re: Phillips F15 T8 CW PLus « Reply #5 on: June 14, 2011, 08:52:58 PM » Author: Powell
I thought it stood for ALTO, as recently I got a 20 watt NON Alto Phillips 5000K color lamp and it did not have green end caps. Well, I could always use a permanent black marker and give them BLACK ends........     ;D
Powell
NNNN!
Powell
Re: Phillips F15 T8 CW PLus « Reply #6 on: June 21, 2011, 01:53:03 PM » Author: Powell
And I could always get a permanent marker and make them BLACK ENDERS! ! !
 ;D ::) :P
Powell
NNNN!
Silverliner
Rare white reflector
Re: Phillips F15 T8 CW PLus « Reply #7 on: June 21, 2011, 10:27:09 PM » Author: Silverliner
Where were they made?
Member of L-G since 2005.
Electrician.
Powell
Re: Phillips F15 T8 CW PLus « Reply #8 on: June 22, 2011, 10:35:17 AM » Author: Powell
USA made.
Powell
NNNN!
thornemi
Re: Phillips F15 T8 CW PLus « Reply #9 on: June 22, 2011, 10:16:54 PM » Author: thornemi
Philips ones here are normally Holland or Poland. GE is Hungary, normally. Sylvania is always Germany, within the EU. Also, you can get the 2ft 18w ones here for under £2, Sylvania Deluxe.
Silverliner
Re: Phillips F15 T8 CW PLus « Reply #10 on: June 22, 2011, 11:10:26 PM » Author: Silverliner
Here in the USA almost all Philips fluorescents are USA made. A few types such as the modern T5s and F15T8s.are made in Holland.
GE is mostly USA made, some come from Hungary. Osram Sylvania is all North America, mostly USA, some from Canada and Mexico.
SLI fluorescents are German.
Electrician.
thornemi
Re: Phillips F15 T8 CW PLus « Reply #11 on: June 22, 2011, 11:52:03 PM » Author: thornemi
Quote
Interestingly GE ones WERE made in England for a long, long time. Then a couple of years ago they started coming from Hungary, so I get Sylvania or Philips now. Crompton are the worst I've used, fell out of the fitting onto my head.
Powell
Re: Phillips F15 T8 CW PLus « Reply #12 on: June 23, 2011, 01:29:58 PM » Author: Powell
I haven't seen a GE made in USA in years. CW in Indonesia...some other colors (K&B Reveal) made in Hungary. I have a GE CW made in Chile, though!
I have only seen USA made Phillips. For the 6 and 8 watt T8 lamps.... mostly China NOW
Powell
NNNN!
Silverliner
Re: Phillips F15 T8 CW PLus « Reply #13 on: June 23, 2011, 05:28:22 PM » Author: Silverliner
Powell
I suppose you are talking about the F15T8 lamps specifically.
Electrician.
Powell
Re: Phillips F15 T8 CW PLus « Reply #14 on: June 23, 2011, 05:50:36 PM » Author: Powell
Yes, I was....... ;D
Powell
NNNN!
