Author Topic: Effects of turning on fluorescent nightlights on their lamp lifespan  (Read 4271 times)
Effects of turning on fluorescent nightlights on their lamp lifespan « on: June 23, 2011, 09:26:11 AM » Author: dor123
Because the fluorescent lamps in fluorescent nightlights are so small and have very low wattage, they can be ignited from the mains voltage easily, with a simple resistor system and without a starter or a HV device.
However, despite the low voltage that applied during the starting, each starting the nightlight, still erodes the lamp electrodes and dramatically affects their lifespan.
Why this is happens?
imj
Re: Effects of turning on fluorescent nightlights on their lamp lifespan « Reply #1 on: June 23, 2011, 12:37:46 PM » Author: imj
The electrodes are not heated and running on low power means it's running cold or below thermionic emission of the electrodes and that creates alot of sputtering. The same thing happens to HIDs during warm up and striking so you can usually see blackening of the ends of the discharge tube during warm up and disappears after it fully warmed up because the burnt material gets into the arc and gets deposited behind the electrodes.
Re: Effects of turning on fluorescent nightlights on their lamp lifespan « Reply #2 on: June 23, 2011, 03:59:35 PM » Author: Medved
Exactlz, even if there is no HV boost, the lamp start in an InstantStart manner with all consequences.
Moreover the most popular series capacitor ballast cause quite high current crest factor, what does not do anything good as well.
And it does not matter, if the discharge start directly across the tube, or with the aid of starting probes, in both cases the discharge start on cold electrodes.
Re: Effects of turning on fluorescent nightlights on their lamp lifespan « Reply #3 on: June 23, 2011, 04:19:24 PM » Author: Ash
If you are speaking about those <50 mm 3W fluorescent, open the case and look inside - the one i seen uses a probe start on both ends, similar to mercury lamp
Re: Effects of turning on fluorescent nightlights on their lamp lifespan « Reply #4 on: July 08, 2011, 12:31:22 AM » Author: dor123
Most of my fluorescent nightlights i had, didn't used starting electrodes and starting probes at all.
Re: Effects of turning on fluorescent nightlights on their lamp lifespan « Reply #5 on: July 08, 2011, 02:44:56 AM » Author: Ash
I have one with them somewhere, can post pics if i find it. Its Jeko 3W it was bought in Shupersal
