Author Topic: Oversized CFL and MOT  (Read 19191 times)
Oversized CFL and MOT « on: September 15, 2011, 02:09:36 AM » Author: Medved
Somebody got bored...
Re: Oversized CFL and MOT « Reply #1 on: September 15, 2011, 05:06:28 AM » Author: sol
...and doesn't care about safety. One should never spray water on electrical fires. He surely cut the power supply before spraying, but he shows a bad example. Someone might see this and try it at home...
Re: Oversized CFL and MOT « Reply #2 on: September 15, 2011, 06:01:46 AM » Author: Ash
Spraying water is not that dangerous, since a spray of drops does not have continuous conductive path all the way back to you
If power is still there, it will evaporate the water and catch fire again, maybe with additional excitement from some hydrogen and oxygen from electrolized water, but not let current through the spray
Re: Oversized CFL and MOT « Reply #3 on: September 15, 2011, 02:49:59 PM » Author: Medved
He switched the power OFF just before spraying...
@Ash: But then the water could cause dangerous leaks trough wettened surrounding materials...
Re: Oversized CFL and MOT « Reply #4 on: September 15, 2011, 03:24:37 PM » Author: dor123
Ash: Water + Electricity = Electric shock or a short.
Re: Oversized CFL and MOT « Reply #5 on: September 15, 2011, 03:31:43 PM » Author: Ash
Medved :
Yep, but why would he touch them ?
Assuming thats concrete there, the only risks of fire are either if the fire from the transformer ignites the cable's isolation and the fire goes along the cable (but shouldn't cables be made fire retardant in the 1st place ?), or a spark (of incandescent metal) flying far out of the transformer and landing somewhere flammable. And both could happen without the water anyway
Dor :
Electric shock : won;t happen in this case, since the water is a spray of isolated drops that won't conduct current to the source of the spray
Short : won't happen at high current (high enough to heat the building's wiring), since the water is bad conductor - it has resistance that limits the current. And besides, the heat dissipated on the water's resistance causes it to boil away and break the circuit
What can happen is some arcing which would ignite the hydrogen and oxygen produced from the water electrolysis, but i doubt that the quantity is enough to make anything exciting
« Last Edit: September 15, 2011, 03:38:19 PM by Ash » Logged
Peach_Lover
https://www.facebook.com/
Re: Oversized CFL and MOT « Reply #6 on: September 15, 2011, 03:49:31 PM » Author: Peach_Lover
Everything else aside when the lamp's that big it ceases to be a "CFL" ;D
Re: Oversized CFL and MOT « Reply #7 on: September 15, 2011, 05:24:32 PM » Author: Ash
Indeed, why not just use a more compact, efficient, and longer lasting halide ?
Re: Oversized CFL and MOT « Reply #8 on: September 15, 2011, 08:26:49 PM » Author: sol
@Peach_Lover : Why not rename it a BFL, which stands for bulky fluorescent, instead of CFL...
Peach_Lover
Re: Oversized CFL and MOT « Reply #9 on: September 15, 2011, 08:46:31 PM » Author: Peach_Lover
@Sol: Hahaha I like it!
That bulb is massive, I can't imagine anyone using it for anything other then growing "stuff" if you know what I mean :-\ Well maybe photography/video, but in that case it'd have to have a darn good CRI and would be too costly to be doing experiments like this with.
nogden
Nelson Ogden
nelson.ogden w8nwo
Re: Oversized CFL and MOT « Reply #10 on: September 15, 2011, 09:49:29 PM » Author: nogden
I like his Variac, wish I had one that big!
Re: Oversized CFL and MOT « Reply #11 on: September 16, 2011, 02:06:32 AM » Author: Medved
The "compact" here does not mean, the thing is small, but then everything necessary (lamp plus ballast) is packed into one unit.
These creations are "riding" on the CFL wave (created by "green brainlesses")...
But in such size the adapter for a HID of the same output should be possible to make (assume it is designed only for ~1..2x lamp life)...
Re: Oversized CFL and MOT « Reply #12 on: September 16, 2011, 05:25:25 AM » Author: Ash
A proper magnetic ballast for 150w MH (that will last tens of times the lamp life) + ignitor + lamp are not larger than this CFL
Re: Oversized CFL and MOT « Reply #13 on: September 16, 2011, 01:57:56 PM » Author: Medved
@Ash: Bot it would be too heavy for the E40 lampholder...
Re: Oversized CFL and MOT « Reply #14 on: September 16, 2011, 02:12:58 PM » Author: Ash
Why would you have a fixture with E40 socket which is not HID fixture ?
And i think it will work no problem in E40, the E40s i seen are very well built
