Author Topic: LED Panel Lamps  (Read 4067 times)
LampLover
120/240VAC @ 60HZ
LED Panel Lamps « on: November 25, 2011, 10:14:42 PM » Author: LampLover
I found a vintage Receiver in the trash and I want to replace the incandescent lamps with LED replacements
There are six lamps five clear @ 6.3VAC and one Red @ 6VAC
Any one know where to get a these?
All I can find is 12VDC for cars/Trucks
I need a 6VAC lamp with an MES (Miniature Edison Screw E10)Base
Thanks
LED Free Zone!
Re: LED Panel Lamps « Reply #1 on: November 26, 2011, 02:26:46 AM » Author: Ash
You can make your own modules for any voltage with just LEDs and resistors
You can connect 6V AC to a doubler to get about 17V DC. Then use a 12V module which is ballasted by resistors (not linear regulator or PWM) and connect extra power resistor in series with it to drop the extra 5V
Powell
Re: LED Panel Lamps « Reply #2 on: November 28, 2011, 09:38:55 AM » Author: Powell
There are companies that make these, but I don't remember who they are.  Just that the #47 replacement  CAN NOT be used as the single lamp run off the tap of the rectifier tube on a a radio that is an AC / DC model.
NNNN!
