Author Topic: Getting Rust off a Pre-Heat Choke Ballast  (Read 4947 times)
LampLover
120/240VAC @ 60HZ
Getting Rust off a Pre-Heat Choke Ballast « on: May 02, 2012, 02:37:47 AM » Author: LampLover
I have a Ballast that I pulled from a broken fish tank fixture and I want a way to get surface light surface rust off (The ballast is for 1 F8T5 Fluorescent lamp)
I already have a Rotary Tool with a polishing tool and a wire brush I just did not know which one to use or how to go about the technique to removing rust
Thanks
I attached a picture of the ballast
LED Free Zone!
SeanB~1
Re: Getting Rust off a Pre-Heat Choke Ballast « Reply #1 on: May 02, 2012, 03:08:09 PM » Author: SeanB~1
Scouring pad, then wipe with a clean dry cloth and then paint with enamel paint. Nothing rough, just light application of the green side of a brand new scouring pad, then remove the fine dust. Best paint is Hammerite , white will match most stove enamels, but it will eventually discolour with years of heat.
Re: Getting Rust off a Pre-Heat Choke Ballast « Reply #2 on: May 02, 2012, 05:27:30 PM » Author: Ash
I have a 150W HPS ballast which i painted with white spray enamel for washing machines / fridges (ballast with about 15W in heat losses on the ballast, and some heat from being in a fixture not far from the lamp)
After few hours of work the paint smells a bit and the 1st time there was also a bubble that blew in the paint from where it is on the coil. The paint appears to be overheating a bit
I guess that with 8W fluorescent ballast, no paint directly on the coil, and no hot lamp right next to it, it won't overheat that bad
slipperypete
Re: Getting Rust off a Pre-Heat Choke Ballast « Reply #3 on: August 14, 2012, 05:32:15 AM » Author: slipperypete
You can also use bulk Scotch brite as well. Its similar to Scotch brite scour pads but used in the industrial market.
Bulb bans = Fascism
