Author Topic: Desk lamp failure tonight  (Read 7934 times)
Powell
Desk lamp failure tonight « on: August 26, 2012, 01:35:14 AM » Author: Powell
I went to turn on the desk lamp that is the night light for the kitchen. The Westinghouse F15T12D just glowed dimly. I tried 3 more  times same result with no starter working. I took the bottom plate loose and the starter socket fell apart. GRRR! I don't have any spares, so off to eBay it is. No place around here has any and that includes the hardware store that has antique stuff. I had another desk lamp that I had converted to a starter start, and it has a missing wire nut, and I couldn't find those either. They are in a "safe" place....wherever that is.  I finally got another desk lamp that accepts T12 lamps and put in the Westinghouse.
NNNN!
Re: Desk lamp failure tonight « Reply #1 on: August 26, 2012, 10:21:38 AM » Author: Ash
Mordern starter socket does not fit in ?
Powell
Re: Desk lamp failure tonight « Reply #2 on: August 26, 2012, 10:43:48 AM » Author: Powell
Can't FIND modern starter sockets ??? ???. I can get lamp sockets with starter built in. Can't use that. Remember the US is not preheat / switch start unless it is 20 watts and under, and modern 20 watt units have been trigger/rapid start for some time.  I think eBay it will be.....   ??? :-\ :'(
NNNN!
Patrick
Webmaster
LightingGallery
Re: Desk lamp failure tonight « Reply #3 on: August 26, 2012, 02:27:14 PM » Author: Patrick
Would any of these starter sockets work for your purposes?
http://semperlite.com/products/lampholders/list.php?B1=61
Patrick C., Administrator
Powell
Re: Desk lamp failure tonight « Reply #4 on: August 26, 2012, 02:42:20 PM » Author: Powell
Yes, and I found some on eBay. I will be ordering later this week.
NNNN!
Powell
Re: Desk lamp failure tonight « Reply #5 on: September 02, 2012, 10:07:23 PM » Author: Powell
 Starter sockets came, got wire nuts and repaired unit. RATS! My F15T12D Westinghouse lamp (well I bought a case of these) already has a little black spot on one end. I put a Dura FS-2NA starter in. That's an automatic reset starter as the socket is in the base of the lamp with the ballast. I also repaired another lamp with a wire nut as I had converted this one to starter start and not a button. Whoever had it before had put in 2 switches one for a manual preheat. I had to replace the ballast with that one as the bulb was VERY bright and after 30 minutes the ballast was so hot you couldn't touch it.
NNNN!
Re: Desk lamp failure tonight « Reply #6 on: September 03, 2012, 11:33:45 AM » Author: Ash
Is the lamp blink happy ? If it is this may be the reason for the end blackening
And what type of ballast is the one that overpowered the lamps/overheated ? Is it of the correct ratings ?
Powell
Re: Desk lamp failure tonight « Reply #7 on: January 08, 2013, 01:06:20 PM » Author: Powell
No, the lamp blinked once.  I now have one of the ultra cheap Chinese F15T8D Sunlite bulbs in it I commented on elsewhere. It starts with one blink... sometimes 2.
NNNN!
