Author Topic: esl light  (Read 10328 times)
marcopete87
esl light « on: February 21, 2013, 03:14:58 AM » Author: marcopete87
Hi all.
Yesterday, while surfing on some e-shop, i saw an esl lamp at (i think) low price.
Does someone know anything about this kind of lamps?
Re: esl light « Reply #1 on: February 21, 2013, 05:51:03 AM » Author: dor123
ESL = Electron stimulated luminescence .
This lamp is essentially a miniature Cathode Ray Tube (CRT), without a magnetic or electrostatic deflection, without a shadow mask and with a single phosphor panel unit (Rather than many RGB phosphors pixels in a CRT dispaly), that have rare-earth triphosphors (Rather than the traditional RGB phosphors of CRT display tube). Electrons stikes them to produces light like how a CRT produce a picture.
Colour rendering is same as CFL (Ra8=85). Colour temperature range is the same as CFL and LED (2700K, 3000K, 3500K, 4000K, 5000K and 6500K), and as the electronic power supply, is integrated into the lamp (Like CFL and LED), the life is similar to CFL and LED (6000 hours average), and the efficiency is the same as CFLs (45-60 lm/w).
The only real adventage of ESL over CFL, is the absence of mercury. Otherwise, ESL, like LED, needs to be recycled as any other electronics stuff.
« Last Edit: February 21, 2013, 05:54:05 AM by dor123 » Logged
marcopete87
Re: esl light « Reply #2 on: February 21, 2013, 08:19:14 AM » Author: marcopete87
thank you very much!
do you think is an valid incandescent replacement in cold places?
Re: esl light « Reply #3 on: February 21, 2013, 09:07:17 AM » Author: dor123
As CRTs aren't affected by temperature, ESL shouldn't reduces performance in cold places, likes LEDs. But unlike LEDs, they willn't have an increase in performance and brightness, but only in lifespan (Down to a threshold, where electrolytic capacitors (If present at all), will reduces performance, as their electrolyte would be frosted.
marcopete87
Re: esl light « Reply #4 on: February 21, 2013, 10:32:45 AM » Author: marcopete87
uhm... according to Vu1 website, their lamp is 25 lm/W; not much impressive  :-\
Re: esl light « Reply #5 on: February 21, 2013, 11:42:22 AM » Author: Ash
Given how they work, i would not expect too much efficiency either
As far as driver goes, CRTs are hot cathode tubes so i'd expect ESLs to be hot cathode too, as such they may reqiure more complex ballast (eg permanent heating and the like)
If those have capacitor-less ballast (like some LED ballasts are), there is reliability advantage. If no, then it does not look as interesting. Then, here may be other advantages to look for :
No mercury - greener product
Different failure mode - for example dimming with time and not abrupt failure (ie lamp life rated by light output and not by lamp survival) - which is a big advantage for multiple lamp installations
« Last Edit: February 21, 2013, 11:47:45 AM by Ash » Logged
marcopete87
Re: esl light « Reply #6 on: February 21, 2013, 12:04:49 PM » Author: marcopete87
as electron emitter, will fluorescent cathode act the same in vacuum?
Re: esl light « Reply #7 on: February 21, 2013, 12:49:19 PM » Author: Ash
In CRT its about the same - basicaly a filament or filament-heated cathode that emits electrons
But CRTs have life of many years permanent on - they degrade mostly by phosphor degradation. But CRTs have way lower power than lamps as well
Re: esl light « Reply #8 on: February 21, 2013, 02:35:54 PM » Author: Medved
It would emit the electrons in the same way, but you need a phosphor to convert the electron beam to light.
Quote from: Ash
In CRT's all the beams have to originate from tiny cathodes in order to be focused back into a small spot on the screen, so to get sharp image. And that yield quite high cathode loading, what had to be compensated by the use of really high voltages to get enough energy to emit multiple photons from single electron. The consequence was the degradation of the cathodes, what required more complicated circuits to compensate for it and to avoid overloading, so the useful CRT life become sufficient. Without that the CRT usually lasted for rather short time...
Re: esl light « Reply #9 on: February 22, 2013, 01:02:43 PM » Author: Ash
The design of ESL have less restraints than CRT, so it can be made better in all the parameters needed for ESL lamp - bigger electrodes and so on
Re: esl light « Reply #10 on: February 22, 2013, 03:01:14 PM » Author: Medved
That is true, but even with that, the performance is way worse than other available technologies. Of course, it is mainly due to it's infancy, so it technically could be improved. But because the technology does not allow to be cheaply manufactured (unlike the LED's), so generate reasonable profit, there would be no investment in that area and all makers would rather invest into the LED, where the performance is already better and yet it is promising to give good return of investments.
marcopete87
Re: esl light « Reply #11 on: February 22, 2013, 06:43:47 PM » Author: marcopete87
9.99€/bulb on amazon, made (or marked) by paulmann...
it isn't so expensive...
Re: esl light « Reply #12 on: February 23, 2013, 12:53:58 AM » Author: Medved
Exactly, the selling prices are low, so where is the margin for the makers?
Nobody would invest a penny into a technology, where the selling prices are already low, while the manufacturing costs have no expectation to go down.
Don't forget, than LED's are sold for $30 (they could be, because their efficacy is nearly twice as high), while their manufacture cost is expected to drop to $3, so the vision of $27 margin on each bulb is quite a strong force pushing everybody into that area...
marcopete87
Re: esl light « Reply #13 on: February 23, 2013, 03:13:19 AM » Author: marcopete87
in local store i can find them in prices from 4€ to 15€, more if i want some good philips bulbs.
however, if esl don't gain the same efficiency of leds and cfl, i think they'll disappear early.
Re: esl light « Reply #14 on: February 23, 2013, 04:31:55 AM » Author: dor123
CFLs have usually 45 lm/w average: Not better than MV lamps.
LEDs have up to 60 lm/w, as a LED lighting product can't reach more than this outside the laboratory. The very high efficiencies of from 75 lm/w to 3 digits lm/w, were actually achieved only with discrete HPLEDs in lab conditions, which in regular uses, either the LED will fry in secs, will have lower efficiency or will be horribly expensive.
The most common reason for the very high brilliance of 5mm LEDs today, isn't some improvments, but these LEDs simply feed with x2 and even more of their rated current (Overdriven).
But even if they are feed with their rated current, they can still have very short life if they are crowded in a very small space, with no cooling spaces. Of course, these LEDs can't depress their heat to the outside world.
