Author Topic: ho preheater?  (Read 5025 times)
toomanybulbs
ho preheater? « on: May 05, 2013, 08:43:48 PM » Author: toomanybulbs
remember i posted the f48 ho tubes new in box?
funny how things happen but a friend has a garage we fix up stuff in.
the "attic" is a crude platform to store lightweight stuff in.i looked up at it and saw a approx 4'x2' plywood patch in it.
i joked that someone of my build must have gotten up there and came through.
no "thats an antique fixture that i am just keeping clean.cant buy bulbs for it but since it was put in in 61 when my grandfather built the place we are just preserving it".
since i cant get up there to see it i had him take the board off.
rdc sockets.hmmm.
wanna run me to the shop?i think i have these!
well it works fine with these!
he said it has huge starters bigger than a d battery.
it definatly is a preheater.lots of loud pinging and clicking on startup.
i thought ho were all rapid start.
h will lower it for pics and to see if the ballast temp is safe.
its sure a bright sucker!
Re: ho preheater? « Reply #1 on: May 06, 2013, 12:16:04 PM » Author: Ash
Sounds like a cool adventure you had there....
There are Preheat HO ballasts, well not exactly but pretty close....
I have one for 1x110w HO on 240v 50Hz. It is labeled Quick Start but it is actually Capacitive Preheat with ordinary 2-pin electronic starter hidden inside the ballast enclosure (the starter can be swapped with a glow starter then it would be even more Preheat then it is now....)
The UK 100w and 125w 8ft T12s run on a mercury HID ballast which specs are 1.15A (at least when used with the mercury lamp), so i guess that would count as HO despite the tubes are not normally called HO. Starting is with  starter
toomanybulbs
Re: ho preheater? « Reply #2 on: May 06, 2013, 03:48:46 PM » Author: toomanybulbs
this is a big heavy shoplight type fixture with the ballast and starters on top in a box.
120vac us spec.
so when were ho lamps with rdc base introduced?
DieselNut
John
Re: ho preheater? « Reply #3 on: June 13, 2013, 09:38:13 PM » Author: DieselNut
You have GOT to post photos please!  The first HO (actually VHO) were the 90 and 100 watt T17s in the early 1940s.  I would love to see the ballasts and starters in that thing!  The 90/100 watt T17s have starters the size of a D battery but I have never seen any for anything smaller in the USA market...
Preheat Fluorescents forever!
