Author Topic: Streetlights in communities that are powered by FIRST ENERGY  (Read 2926 times)
CrestwoodOhio
josephmatthews535
Streetlights in communities that are powered by FIRST ENERGY « on: April 30, 2014, 10:19:33 PM » Author: CrestwoodOhio
For those who live in communities or been in communities that are powered by FIRST ENERGY's Ohio Edison, Illuminating Company, Toledo Edison, Met-Ed, Penelec, Penn Power, West Penn Power, Jersey Central Power & Light, Mon Power, Potomac Edison:
You can REPORT any STREETLIGHTING PROBLEM in those areas by clicking: https://www.firstenergycorp.com/content/customer/service_requests/report-lighting-problem.html
Is there power in the immediate vicinity of the affected light? You would Click Yes. (If no, then you would cant to call 1-888-544-4877 immediately)
Does the light present a hazardous situation such as broken glass or lens, the fixture is in danger of falling, the wires are exposed, the pole is damaged, leaning or knocked down? You would Click No. (If yes, then you would cant to call 1-888-544-4877 immediately)
If Yes on the first question and No on the second question, then the next question is:
What type of lighting problem are you reporting? You would want to put a dot at STREETLIGHT (or OUTDOOR if it is like a Security Light installed in your driveway area or your house like a Security Light or so)
If you put a dot at STREETLIGHT and if you do not have an online account with First Energy,
then you would click: https://www.firstenergycorp.com/service_requests/report-lighting-problem.html?form=
You options in reporting a streetlight problem are: Light is not on at night, Light stays on during day, Light cycling on and off and/or flickering dim.
That would make you show a good deed.
« Last Edit: April 30, 2014, 10:52:17 PM by CrestwoodOhio » Logged
6500K Color Temperature Kelvin lighting works for me. I use 6500K CFL in all my incandescent light fixtures. I use 6500K Flurescent bulbs in my flurescent fixtures. I hope prices get better and hope I find 6500K LED lighting in the future. I love energy efficient and Energy Star products. Way to go!
