Author Topic: result of 3 years 24/7/365 on double driven phillips f17t8/tl950  (Read 3158 times)
toomanybulbs
result of 3 years 24/7/365 on double driven phillips f17t8/tl950 « on: July 25, 2014, 08:56:28 PM » Author: toomanybulbs
had noticed ge style end banding on a few of these.
i fixed up a fixture for the garage the same way and lit it to test.
these are 2x 2"fixtures with the lamps out the edges and notched on the broad side for 2 more lamps.
inside is a 4 lamp is ballast wired 2x drive and the lamps in series on each side.
anyway the fresh tubes were twice as bright as the ones that had been in use 3 years!
planned to relamp everything when i had time.
well a few started failing.long story short it took 3 years to beat these tubes to death.
doubled the brightness of my work area!
BlueHalide
Re: result of 3 years 24/7/365 on double driven phillips f17t8/tl950 « Reply #1 on: July 25, 2014, 11:58:58 PM » Author: BlueHalide
Overdriving normal output lamps is an inexpensive way to get high output but should only be done with instant-start electronic ballasts.
toomanybulbs
Re: result of 3 years 24/7/365 on double driven phillips f17t8/tl950 « Reply #2 on: July 26, 2014, 03:51:16 AM » Author: toomanybulbs
btw the phillips tl950 shift to the pinkish side as they age.
these are older tubes pre alto crap.
relamped with a mix of those and pre ecologic sylvania 950.
we will see which holds up best.
