Author Topic: Mercury ballast as an autottransformer.  (Read 3878 times)
Mercury ballast as an autottransformer. « on: June 15, 2015, 09:31:19 AM » Author: Solanaceae
I recently bought a three pack of advance quad tap ballasts on eBay. They are tapped for 120,208,240, and 277. I've heard that you could do this on here, but I need to verify it. Could I use the other taps as a step up transformer if I use the 120 tap and could I have it as a step down transformer if I used the 277 tap with 277v?
Re: Mercury ballast as an autottransformer. « Reply #1 on: June 17, 2015, 11:17:28 PM » Author: Medved
Yes, the maximum load in VA is then the nominal ballast wattage.
I would guess quite good thing for the 240V or similar experiments...
lights*plus
George Liv Photo
Re: Mercury ballast as an autottransformer. « Reply #2 on: August 07, 2019, 05:08:03 AM » Author: lights*plus
Wait a minute here..
I take a 120/277/347volt HPS or MH ballast and I simply wire (for Canada 120V) the 120V/COM & ground the ballast core.
Then from that I use the 347V tap with the COM to power another HID ballast that only has a 347volt tap? Like the SOX 135w ballast pictured? That doesn't sound right.
