Author Topic: not engrish but about as bad  (Read 5886 times)
toomanybulbs
not engrish but about as bad « on: September 02, 2015, 09:37:31 PM » Author: toomanybulbs
http://www.ballasts.com/robertson-sp258a
some sort of bot?
The Robertson SP258 /A is a Magnetic Ballast that operates (1) F25T12 lamp 120 at 120V This ballast is great for areas that require normal lighting! Armed with a Pre-heat starting method, this ballast is used in office, board rooms, and retail. Also operates Fluorescent lamps.
Re: not engrish but about as bad « Reply #1 on: September 02, 2015, 09:59:26 PM » Author: Solanaceae
I don't know which is worse, the price or the grammar.
Re: not engrish but about as bad « Reply #2 on: September 02, 2015, 10:08:22 PM » Author: sol
"Also operates fluorescent lamps" What other lamps does it operate ?
Anyways, 1000bulbs is all out of Advance LC-25 ballasts and can no longer get them. I tried to order and got a message saying it is no longer available.  :( >:( :( >:( :( >:(
Re: not engrish but about as bad « Reply #3 on: September 02, 2015, 10:12:19 PM » Author: Solanaceae
I need the 25w chokes too, but two .30a chokes parallel does a good job for now.
Armed with preheat! « Reply #4 on: September 02, 2015, 11:37:46 PM » Author: Lumex120
"Armed with a Pre-heat starting method"
Can't...stop...laughing! :D
About the only thing that would make this worse is "ideal for use in light fixtures".
Re: not engrish but about as bad « Reply #5 on: September 02, 2015, 11:40:49 PM » Author: Lumex120
More funny stuff:
Specifications
    Type: Electronic Fluorescent
    Start Method: Preheat Rapid Start
    Lamps: one F40T12
    Input Voltage: 120V
    Lamp Wiring: Parallel
Electronic? Preheat rapid start? one f40t12?
Parallel wiring? I thought you used serial on chokes. :P
Re: not engrish but about as bad « Reply #6 on: September 03, 2015, 12:01:08 AM » Author: Solanaceae
The thing is, preheat f30 and above ballasts in 120v land have to be autotransformers or the lamp won't work. I've seen a member (nicksfans) strike an f30t12 with a single 20w choke.
nicksfans
I love discharge lamps!
UCDl2EWWZc9h1IZXcfGU9OZA
Re: not engrish but about as bad « Reply #7 on: September 03, 2015, 03:46:32 PM » Author: nicksfans
@sol: Check this out.
As far as the "offices, board rooms, and retail" thing goes, I'd like to see ONE board room that contains an F25T12 lamp/ballast. ;D
Re: not engrish but about as bad « Reply #8 on: September 03, 2015, 04:31:37 PM » Author: Solanaceae
My homemade 2xf25t12/28" fixture looks like something that'd be installed in some rooms at my hi skool. The rooms that were unaffected by demolition or renovation still have some f40 wraparounds in them, but I'm not completely if they're original condition or retrofitted. I have seen some f40t12 black lights, but new. I asked the teacher about them, but they were used for dances, otherwise I'd've gladly taken them.
marcopete87
Re: Armed with preheat! « Reply #9 on: September 05, 2015, 08:06:56 AM » Author: marcopete87
"Armed with a Pre-heat starting method"/quote]
STOP immediately otherwise i'll preheat you!  ;D
ok, i speak inglish (italian pronunciation of english, if you are curious, use google translator and let him speak in italian), so i'm not getting all errors you are reading  :)
toomanybulbs
Re: not engrish but about as bad « Reply #10 on: September 05, 2015, 12:27:40 PM » Author: toomanybulbs
yes that page is just chock full of FAIL!
btw i use the 25w type to get good output from f20t12 vitalites.
they are less efficient and then most ballasts underdrive them.
there was a .4 amp sylvania i used on the last batch but they are extinct.
Re: not engrish but about as bad « Reply #11 on: September 05, 2015, 12:46:49 PM » Author: Lumex120
Same.  :D
toomanybulbs
Re: not engrish but about as bad « Reply #12 on: September 05, 2015, 12:59:13 PM » Author: toomanybulbs
they might if they have an older range or soda machine.
Re: not engrish but about as bad « Reply #13 on: September 05, 2015, 02:01:07 PM » Author: Lumex120
True...
But I think it means that this is for use in general light fixtures, not appliances
Re: not engrish but about as bad « Reply #14 on: September 05, 2015, 03:41:10 PM » Author: Ash
I'd like to see user reactions when they try to use that with what they really got in the conference room, such as a 32 T8..... (it would just keep flashing with FS2 or do nothing with FS4 starter)
