Author Topic: Wiring temperature rating for a cobra head.  (Read 3358 times)
Wiring temperature rating for a cobra head. « on: September 12, 2015, 09:25:01 PM » Author: Solanaceae
I am getting a westy OV-25 that I'm retrofitting to 175w since the original ballast is 480v. Does anyone know what wire I should use? I'm going to use two capacitors in parallel (10 and 7.5uf) to replace the plastic crapacitor that came default with the kit. The caps are both 370 volts, so I don't have to worry about the compatibility issues. Should I use wire rated for 90 Celsius or should I go for something higher? Thanks.
Re: Wiring temperature rating for a cobra head. « Reply #1 on: September 13, 2015, 07:14:02 AM » Author: Ash
As long as the wiring is in its correct place - away from the lamp compartment and not too close to the ballast, i guess 70C is okay - That is what i see here and it stays fine
For the internal wiring that reaches to the components, you would have to use higher temp wire
For the wiring going to the socket, you would have to use proper high temp wiring - silicone in glass braid sleeve etc
Re: Wiring temperature rating for a cobra head. « Reply #2 on: September 13, 2015, 02:09:24 PM » Author: Solanaceae
Ash, I dug up some wire I had leftover from my NEMA head. The consensus I came to was using the 150 Celsius wire for the wires that go from the ballast, to the cap, and from the cap, to the lampholder. The wires bridging the caps together are 105 Celsius, since they are going to be back near the slipfitter, and heat won't be a big problem. I also have extra fiberglass sleeving to slip around the wires too. That's what I used for the NEMA head. Thanks. :)
