Author Topic: What's the most offensive/wrong lighting article you have seen?  (Read 11908 times)
What's the most offensive/wrong lighting article you have seen? « on: September 14, 2015, 11:07:03 AM » Author: Lumex120
I don't remember where I saw it, but I once saw an article saying you can get mercury
poisoning from standing under  :mv: streetlights. I know that is wrong, and there is literally no way that could happen. >:( >:( >:( >:( :'( :'( :'( :'(
What is the worst article you have seen?
Re: What's the most offensive/wrong lighting article you have seen? « Reply #1 on: September 14, 2015, 11:37:18 AM » Author: Ash
Numerous of them, most common offense is stating the most ridiculous claims of the LED indistry (about how good are LED and how bad are evrything else) as if it were facts
I dont keep track of them but im sure Dor123 can post a few
Re: What's the most offensive/wrong lighting article you have seen? « Reply #2 on: September 14, 2015, 11:38:54 AM » Author: Solanaceae
If that's the case you can get arsenic poisoning from leds. ??? ::)
nicksfans
I love discharge lamps!
UCDl2EWWZc9h1IZXcfGU9OZA
Re: What's the most offensive/wrong lighting article you have seen? « Reply #3 on: September 14, 2015, 12:25:02 PM » Author: nicksfans
I've read that LEDs produce no noticeable heat. ::)
FGS
Rory Mercury!
Re: What's the most offensive/wrong lighting article you have seen? « Reply #4 on: September 14, 2015, 12:25:53 PM » Author: FGS
Getting poisoning from arsenic in LEDs is the mos asinine thing I ever heard. They're deeply buried in the grain of salt sized dies themselves and in trace amounts at that. You'd need to grind them to super fine dust to even get any arsenic in you. (Finer than powdered sugar.)
Re: What's the most offensive/wrong lighting article you have seen? « Reply #5 on: September 14, 2015, 12:30:07 PM » Author: Solanaceae
Felipe, refer to Zarlog's first post. I was doing a spinoff of that.
Re: What's the most offensive/wrong lighting article you have seen? « Reply #6 on: September 14, 2015, 12:55:47 PM » Author: Ash
Felipe Technically you can get arsenic in you by munching complete SMD LEDs. Just sayin'
Re: What's the most offensive/wrong lighting article you have seen? « Reply #7 on: September 14, 2015, 01:04:56 PM » Author: Lumex120
In response to where you heard that: Oh really? Then how come my 100w green LED gets hot enough to melt plastic, even with an ice cube directly on the back of it? And that's not even at half the power. ;D
FGS
Rory Mercury!
Re: What's the most offensive/wrong lighting article you have seen? « Reply #8 on: September 14, 2015, 01:10:21 PM » Author: FGS
True but who's that stupid to go around eating SMD LEDs? ::) LOL!
Re: What's the most offensive/wrong lighting article you have seen? « Reply #9 on: September 14, 2015, 01:14:54 PM » Author: Ash
That is true depending on where you are located VS the LED. Incandescents emit most of their heat as IR, HID emit some of it as IR, but LED and Fluorescent indeed put out nearly no IR - All the heat is ending up on the lamp itself
So if you are standing in the beam of light - Indeed no noticable heat
But if you are touching the lamp.....
Re: What's the most offensive/wrong lighting article you have seen? « Reply #10 on: September 14, 2015, 01:37:27 PM » Author: dor123
The LEDs of the indirect fixtures at our resort room at Ein-Gev resort village, vaporised water on my finger in seconds and was very hot to touch.
Re: What's the most offensive/wrong lighting article you have seen? « Reply #11 on: September 14, 2015, 01:43:19 PM » Author: dor123
1. https://translate.google.co.il/translate?sl=iw&tl=en&js=y&prev=_t&hl=iw&ie=UTF-8&u=http%3A%2F%2Fwww.calcalist.co.il%2Flocal%2Farticles%2F0%2C7340%2CL-3394356%2C00.html&edit-text=
http://www.calcalist.co.il/local/articles/0,7340,L-3394356,00.html
2. https://translate.google.co.il/translate?sl=iw&tl=en&js=y&prev=_t&hl=iw&ie=UTF-8&u=http%3A%2F%2Fwww.ynet.co.il%2Farticles%2F0%2C7340%2CL-3997652%2C00.html&edit-text=&act=url
http://www.ynet.co.il/articles/0,7340,L-3997652,00.html
3. https://translate.google.co.il/translate?sl=iw&tl=en&js=y&prev=_t&hl=iw&ie=UTF-8&u=http%3A%2F%2Fwww.globes.co.il%2Fnews%2Farticle.aspx%3Fdid%3D1000880831&edit-text=&act=url
http://www.globes.co.il/news/article.aspx?did=1000880831
« Last Edit: September 14, 2015, 01:49:26 PM by dor123 » Logged
Re: What's the most offensive/wrong lighting article you have seen? « Reply #12 on: September 14, 2015, 04:01:04 PM » Author: Solanaceae
Maybe a curious kitty kat or a small child.
Re: What's the most offensive/wrong lighting article you have seen? « Reply #13 on: September 14, 2015, 04:05:55 PM » Author: Ash
Perhaps in our homes.... But where does the average user get SMD LEDs from ?
Re: What's the most offensive/wrong lighting article you have seen? « Reply #14 on: September 14, 2015, 04:13:35 PM » Author: Lumex120
"WARNING: energy-saving bulbs contain mercury
In addition to the danger of radiation of energy-saving bulbs - now warns US Environmental Protection Agency that liquid mercury which can cause respiratory problems. Recommendations: When one bulb breaks, has quickly leave the room for at least 15 minutes"
"Energy saving bulbs contain mercury". As if everyone doesn't know that. :P
Radiation? CFL's arent nuclear powered. ::)
Mercury can't cause respiratory problems. It can cause health issues (if one to 5 CFLs break, you should just be worried about the glass, not the mercury. Anything higher than that, you should air out the room for at least 15 minutes, ideally with a fan.), but respiratory problems would be from smoke or dust, not liquid mercury. Leaving the room and not doing anything isn't going to solve the problem. The mercury won't go anywhere. :P ::)
