Author Topic: What is the best fluorescent nightlight?  (Read 4359 times)
light finatic
What is the best fluorescent nightlight? « on: November 28, 2015, 09:41:35 PM » Author: light finatic
Hello all,
I have been getting really mad with fluorescent nightlights lately and I had an Amertac fluorescent one from Home Depot that almost burned down my house and the GE ones don't last.
I may have to get NOS ones online, but what would you recommend for a good fluorescent night light?
Thanks ;)
Re: What is the best fluorescent nightlight? « Reply #1 on: November 28, 2015, 10:06:53 PM » Author: funkybulb
Stick with linear fluorescent.  i use a 110 volt LP40
Fitzegearald lightpack. As my daily nightlight.
Using sylvania CWX lamp
I would stay away from CFL cause they cant be trusted;
Do to it electronics. Also when using CFL u have to inspect yout fixtures for EOL lamp dont let them burn out
In your house.
Re: What is the best fluorescent nightlight? « Reply #2 on: November 29, 2015, 01:08:52 AM » Author: dor123
CFLs here, dies silent at EOL.
Re: What is the best fluorescent nightlight? « Reply #3 on: November 29, 2015, 02:12:49 AM » Author: Solanaceae
From My experience, CFLs die peacefully. I had a few where they would flow at the ends only (bad cap) and if left like that long enough, will result in the smoky failure. Thankfully, I caught one that glowed at the ends and would flicker violently otherwise. The tubes ended up being severely blackened and the circuit board showed signs of overheating.
Re: What is the best fluorescent nightlight? « Reply #4 on: November 29, 2015, 06:03:22 AM » Author: dor123
What cause some of the american CFLs to have an explosive EOL, is because of the use of a doubler.
Re: What is the best fluorescent nightlight? « Reply #5 on: November 29, 2015, 02:10:07 PM » Author: Ash
My computer light is PL on Magnetic ballast
I use it in a posttop pathway lantern, that i retrofitted from HPS (untill i'll decide to change to a new lantern again, and then i'll put the original HPS gear back in this lantern. But i will stay with the PL). In one of the past setups i used a PL bulkhead which i laid on top of a closet, so it lights into the ceiling
Re: What is the best fluorescent nightlight? « Reply #6 on: November 29, 2015, 09:08:42 PM » Author: sol
I use a couple of 8 watt T5 switch start battens as basement night lights. I've never had overheating problems, EOL lamps eventually break an electrode and that's it. At church, I use F15, but those are quite bright for home night light use. They have never overheated even with stuck starters.
At home, I use C7 red Christmas lamps but I have considered using a PL-S of 5 watts in a coloured drinking glass as a night light but never got around to getting the parts let alone build anything. Some members here use an F4 lamp, though.
Re: What is the best fluorescent nightlight? « Reply #7 on: November 30, 2015, 04:09:06 PM » Author: Ash
Getting F4/6/8T5 lamps here in colors <6500K is uncommon, and <4000K is a quest. About only place where they are used is in emergency lighting and exit signs
