Author Topic: Cold cathode fluorescent questions  (Read 3818 times)
Cold cathode fluorescent questions « on: April 30, 2016, 04:46:53 PM » Author: Solanaceae
I want to build some small scale version of the Ccfl consulite fixture that tony has. I saw some small transformers like this for 3.5kv. Would this be enough to run four of the 1/8"Dia, ~24" long tubes in series? I don't know the operating specs of the tubes since the power supply I used has since gone out. I was looking for some small, true "neon" type tubes that were white but no luck.
Re: Cold cathode fluorescent questions « Reply #1 on: April 30, 2016, 05:01:06 PM » Author: Ash
T1/T0.8 CCFLs like in LCD monitors are normally between 4..8mA and 600..800V. This would strike atleast 2 or 3 in series, but i think will overdrive them. Use one of the Electronic inverters made for LCD's instead
Re: Cold cathode fluorescent questions « Reply #2 on: April 30, 2016, 06:50:43 PM » Author: Solanaceae
Oops, these are actually in the range of 15-18 inches.
Re: Cold cathode fluorescent questions « Reply #3 on: April 30, 2016, 07:12:41 PM » Author: Ash
Same applies
nicksfans
I love discharge lamps!
UCDl2EWWZc9h1IZXcfGU9OZA
Re: Cold cathode fluorescent questions « Reply #4 on: May 01, 2016, 11:00:07 PM » Author: nicksfans
I would grab two of these or similar. Each will drive two CCFLs.
Re: Cold cathode fluorescent questions « Reply #5 on: May 02, 2016, 01:44:41 PM » Author: Ash
There are replacement CCFL driver boards for 1 / 2 / 4 CCFLs for repairing LCD screens
