Author Topic: 35w HPS vs 50W MV  (Read 16064 times)
bucket175mv
35w HPS vs 50W MV « on: June 29, 2016, 10:00:54 AM » Author: bucket175mv
What bulb/ballast combination would emit more light, both running of a 120v feed.
1) 35 watt :hps: or
2) 50 watt :mv:?
Thanks.
Re: 35w HPS vs 50W MV « Reply #1 on: June 29, 2016, 10:03:41 AM » Author: wattMaster
35 watt HPS I think, because of the higher efficiency.
But not much more, only about 500 lumens.
bucket175mv
Re: 35w HPS vs 50W MV « Reply #2 on: June 29, 2016, 10:09:48 AM » Author: bucket175mv
Hey thanks for the quick reply!
I just converted a Regent mini bucket fixture to 35w HPS for my front driveway light and after last nights trial run, the fixture is to bright.
I have on order a new 35/39 watt MH ballast and a NOS Philips 50w MV lamp. I'm hoping this will give the light output I'm after.
Do you think the 35/39 watt MH ballast slightly under drive this lamp?
Re: 35w HPS vs 50W MV « Reply #3 on: June 29, 2016, 10:15:18 AM » Author: wattMaster
It will, and the ballast may get burned out because the lamp is too much for it. Sorry for the slow reply, the server login verification acted up again.
The lamp may be OK, but no guarantees.
This situation is like a power supply with no protection trying to power something it can't.
I wouldn't risk it, just get a 50 watt MH ballast, that should be enough, I think, but you should measure the voltage and current to make sure it is not overdriving the lamp.
Try adding more diffusion, that usually helps with high light levels.
« Last Edit: June 29, 2016, 10:31:11 AM by wattMaster » Logged
Re: 35w HPS vs 50W MV « Reply #4 on: June 29, 2016, 10:30:21 AM » Author: Lumex120
50w mercury vapor when operated on a 35w MH ballast is about 2/3 the brightness of a 35w HPS. The visibility and better CRI plus the fact that the light is not as harsh would make me choose the merc over HPS. I just got a 35w MH ballast and it runs a 50w merc perfectly. They are about the brightness of a 150w incandescent, and it would probably be perfect for your application.
bucket175mv
Re: 35w HPS vs 50W MV « Reply #5 on: June 29, 2016, 10:37:32 AM » Author: bucket175mv
Hi there and this is just what I wanted to hear :) I did a lot of research on here and other forms and concluded that if you want to run MV at the correct voltage/current you need to use the next wattage down MH ballast with ignitor removed.
Hence why I just ordered a 35 watt MH ballast to drive a 50 MV lamp. I'm excited to build this fixture!
Re: 35w HPS vs 50W MV « Reply #6 on: June 29, 2016, 10:39:05 AM » Author: wattMaster
I just learned something, didn't know that.
bucket175mv
Re: 35w HPS vs 50W MV « Reply #7 on: June 29, 2016, 10:44:40 AM » Author: bucket175mv
I've learned lots off this site! I always thought a 50w MH ballast would overdrive a 50 watt MV lamp and I don't want an overly bright fixture as I'm trying to build lower light output MV fixtures for residential use.
Re: 35w HPS vs 50W MV « Reply #8 on: June 29, 2016, 04:29:34 PM » Author: Ash
Out of them all, an actual 35W Pulse MH would probably provide the highest Lm
The HPS vs Merc, indeed HPS would put out mire Lm, but Merc put out white light, so there is the question : What lighting do you want to achieve, and up to what distance from the lantern ? Depending on that either the Merc or HPS can be the best choice
Re: 35w HPS vs 50W MV « Reply #9 on: June 29, 2016, 05:14:21 PM » Author: AngryHorse
Yeah, if you say 35watt HPS is too bright, 50watt MV would be the better choice, as well as white light, its also diffused, and its traditional MV!
I use to run a 70watt HPS in my front yard, but this was way over bright, but I have settled with a trusty 50watt MV now, and at 1800 lumens, its just enough. 8)
Re: 35w HPS vs 50W MV « Reply #10 on: June 29, 2016, 05:53:30 PM » Author: Solanaceae
Yep, 50w MV is juicy, but 75 or 80 is great too. 50 and 75w MV ballasts are rare here unfortunately, but I managed to find a 50w MV ballast and put it in a flood lite. A 39w magnetic MH ballast without Ignitor is a good ballast with 50w MV and runs them perfect. A 100w MV CWA ballast with a 7.5-8uf cap can run 75w mercs.
Re: 35w HPS vs 50W MV « Reply #11 on: June 29, 2016, 05:57:26 PM » Author: Ash
Use Fluorescetn ballasts for the Merc lamp then
Re: 35w HPS vs 50W MV « Reply #12 on: June 29, 2016, 07:21:11 PM » Author: Solanaceae
Well, it's kinda tricky here, since 40w is underpowering and magnetic preheat ballasts for 5ft and up are practically nonexistent here sadly. :(
bucket175mv
Re: 35w HPS vs 50W MV « Reply #13 on: June 30, 2016, 09:39:08 AM » Author: bucket175mv
I'll get you a pic of the area where I have mounted the fixture so you can get an idea of what I'm after.
bucket175mv
Re: 35w HPS vs 50W MV « Reply #14 on: June 30, 2016, 09:44:11 AM » Author: bucket175mv
Nice! Did you have a pic of your 50 watt :mv: fixture?
I think when Regent made these "mini bucket" type fixtures they went overboard with the lamp and ballast wattage's. The MV fixtures should have had a 50 watt bulb and ballast vs 100w setup and the HPS should have been 35w vs 70 watt.
Hence why these were not in production for very long.
