November 24, 2026, 04:46:55 AM
General
General Discussion
Remote ballast enclosure
Topic: Remote ballast enclosure (Read 3827 times)
« on: July 31, 2016, 10:42:20 PM »
I'm thinking about a small project for which I would need an enclosure for a remote ballast (magnetic with capacitor and ignitor) for 50w MH lamps. Ballast-to-lamp distance would be quite short (less than 4 feet). This needs to be weatherproof. Any ideas on what I could use as a proper remote ballast enclosure is not readily available at the moment ? Thanks for your responses.
Re: Remote ballast enclosure
« Reply #1 on: July 31, 2016, 10:45:15 PM »
What material? PVC, Aluminum, Iron, I assume plastic would be fine?
SLS!
(Stop LED Streetlights!)
« Reply #2 on: August 01, 2016, 01:35:59 AM »
Big connection box or electric panel box ?
Also if you use superimposed ignitor you can place it with the lamp and not with the ballast, then the cable run between them is unlimited in length and is not exposed to ignitor voltages
« Reply #3 on: August 01, 2016, 07:59:01 AM »
I'm looking for a metal enclosure that would house ballast, capacitor and ignitor. Ideally it should be around 6x6x4 inches or 15x15x10 cm. It must be weatherproof, though.
« Reply #4 on: August 01, 2016, 08:37:36 AM »
So why not connection box or panel box made for outdoors ?
« Reply #5 on: August 01, 2016, 09:56:45 AM »
I have a 35w PSMH outdoor ballast box that is in some sort of NEMA enclosure. Here is a 70w version with a larger enclosure.
http://www.ebay.com/itm/Kichler-15MHS70AZT-HID-Landscape-120V-Ballast-70W-Single-MH-Architectural-Bronze-/172119127688?hash=item2813197688:g:GyUAAOSwx-9W1bqc
