Author Topic: OLED Lighting  (Read 5862 times)
OLED Lighting « on: September 29, 2016, 06:47:27 PM » Author: wattMaster
What do you think of OLED as general lighting?
At least it has "Organic" in its name, so it can be easily marketed to "green" people.
RCM442
Re: OLED Lighting « Reply #1 on: September 29, 2016, 08:18:10 PM » Author: RCM442
OLED is not for general lighting, it was designed for screens. It would degrade veey quickly in general lighting use!  ::)
Re: OLED Lighting « Reply #2 on: September 29, 2016, 08:23:43 PM » Author: wattMaster
But OLED panels are planned to be available for general lighting.
RCM442
Re: OLED Lighting « Reply #3 on: September 29, 2016, 08:26:17 PM » Author: RCM442
Not sure how long they will last...
Re: OLED Lighting « Reply #4 on: September 29, 2016, 08:34:38 PM » Author: wattMaster
I would expect higher heat dissipation capability because they have a bigger surface area.
Re: OLED Lighting « Reply #5 on: September 30, 2016, 01:57:04 AM » Author: Ash
The higher surface can done with non O LEDs as well. With OLEDs it is simply a must because the materials used are WAY more vulnerable to heat than in non O LEDs
Re: OLED Lighting « Reply #6 on: September 30, 2016, 01:58:39 AM » Author: dor123
The fact that it is organic, don't means that it is "Green". "Organic" often used as a greenwashing marketing term.
Also: OLED displays have shorter life than LCDs and plasmas and LED displays, because of the limited lifespan of the organic materials.
Re: OLED Lighting « Reply #7 on: September 30, 2016, 02:53:01 AM » Author: Medved
There is indeed higher heat dissipation area, but the OLED's are way more sesitive devices, so the temperature is way more limited. Therefore the attainable light intensity would be way lower than with other light sources.
On the other hand its format allows virtually any shape, it even allows to be custom cut on site, so allows installation on even complex wall shapes,...
So in an interior lighting the use will be mainly large glowing surfaces (drop ceilig tiles,...), so a more eficient alternative to the indirect illumination.
nicksfans
Down with lamp bans!
GoL UCDl2EWWZc9h1IZXcfGU9OZA
Re: OLED Lighting « Reply #8 on: October 01, 2016, 03:34:52 AM » Author: nicksfans
There are, in fact, commercially-available OLED light fixtures.
My Gallery
YouTube
Re: OLED Lighting « Reply #9 on: October 01, 2016, 03:45:15 AM » Author: dor123
The spectrum of OLED lighting is virtually three peaks in the RGB, similar to OLED screens.
Re: OLED Lighting « Reply #10 on: October 01, 2016, 10:08:51 PM » Author: wattMaster
Sounds like low CRI.
Re: OLED Lighting « Reply #11 on: October 02, 2016, 02:44:44 PM » Author: Ash
Light quality would be better than the standard LEDs if they do the non Blue bands right
Re: OLED Lighting « Reply #12 on: October 02, 2016, 03:47:17 PM » Author: Medved
The white OLED display I have is clearly a blue LED plus a phosphor - there is a distinct narrower blue band (but wider than common with the monocrystal LED's), plus green-yellow continuum (typical phosphor response). The display is by far not designed for any color rendering or so, it is just "some white"/black binary pixel matrix (pixel could be just ON or OFF, it even does not allow anything between).
