Author Topic: 200 LPW LED GLS lamps coming out  (Read 8234 times)
Silverliner
Rare white reflector
200 LPW LED GLS lamps coming out « on: October 11, 2016, 12:00:18 PM » Author: Silverliner
See here:
http://www.solidstatelightingdesign.com/philips-partners-city-dubai-create-200-lpw-filament-led-bulbs/
Look at all those LED filament bars. Can't be that cheap to make.
Member of L-G since 2005.
Electrician.
Re: 200 LPW LED GLS lamps coming out « Reply #1 on: October 11, 2016, 12:54:30 PM » Author: Ash
Actually they can - that is the thing with semiconductor production. Once you can make one it does not cost the same effort per piece to make many more
What they optimized there that gave the nearly double boost in Lm/W ?
Re: 200 LPW LED GLS lamps coming out « Reply #2 on: October 11, 2016, 01:02:17 PM » Author: Lumex120
The filaments are probably underdriven giving them higher efficiency (that is why the L-prize lamp claimed to be so efficient)
Silverliner
Re: 200 LPW LED GLS lamps coming out « Reply #3 on: October 11, 2016, 01:36:57 PM » Author: Silverliner
At least they are still normal light bulbs, not a plastic and metal electronic gadget shaped like a bulb.
Electrician.
Re: 200 LPW LED GLS lamps coming out « Reply #4 on: October 11, 2016, 01:50:03 PM » Author: Ash
The LED can be only so much (to a limited extent) efficient at low driving current. Any higher efficacy means that something in the building of the LED is changed
There are users who find the "gadget lamps" appearance cool, so why not. And in many luminaires the lamp is behind frost/opal/"dirty Glass" (by design) diffusers so the light and dark sides of the "gadget lamps" are smoothed out by the lumianire. There a cheaply built "gadget lamp" would have cost advantage over filaments that nobody can see
What interests me is - In this lamp the efficacy is good, the distribution is good, but what about the spectrum ? Is that any changed vs. the usual LED lamps ?
Silverliner
Re: 200 LPW LED GLS lamps coming out « Reply #5 on: October 11, 2016, 03:05:52 PM » Author: Silverliner
How are standard gadget LEDs cheaper than filament LEDs? The latter is lightweight, has no expensive heat sink, are getting easier to manufacture, etc.
Electrician.
Re: 200 LPW LED GLS lamps coming out « Reply #6 on: October 11, 2016, 03:48:54 PM » Author: AngryHorse
200 lm/W is impressive yes, but note how they stop at 3 watts, (and again 600 lumens)!, the limit of their cooling effectiveness?
I want to see a 200 lm/W, 35watt, 7000 lumen lamp that really can replace HPS/MH, then I will be proper impressed.
Re: 200 LPW LED GLS lamps coming out « Reply #7 on: October 11, 2016, 04:02:32 PM » Author: Ash
To make the filament LEDs there is need to poeition and weld the filaments and all the Glass work to make the lamp. The "gadget" things construction is much more crude, in its basic shape just some Plastic injection moulded and Aluminum extruded/cut parts clicked together. It is lower tech product which means that more companies with less advanced manufacturing technology can make it
Silverliner
Re: 200 LPW LED GLS lamps coming out « Reply #8 on: October 11, 2016, 05:42:44 PM » Author: Silverliner
So you mean that standard LEDs will stay and filament LEDs are just a small novelty that will be used in just a few sockets?
Electrician.
Re: 200 LPW LED GLS lamps coming out « Reply #9 on: October 11, 2016, 07:05:13 PM » Author: wattMaster
What about heatsink based LEDs that look like filaments? Those already exist.
Silverliner
Re: 200 LPW LED GLS lamps coming out « Reply #10 on: October 12, 2016, 01:28:51 AM » Author: Silverliner
wattmaster they are called apple lamps. I've seen them.
Electrician.
Silverliner
Re: 200 LPW LED GLS lamps coming out « Reply #11 on: October 12, 2016, 01:30:10 AM » Author: Silverliner
Ash, walmart recently switched to new LED filament candles on the store shelves and they are nearly half the price of the heat sink based ones they replaced. So yes they are cheaper.
Electrician.
Re: 200 LPW LED GLS lamps coming out « Reply #12 on: October 12, 2016, 02:08:55 AM » Author: Ash
There are many other things that affect the sale price they slap on things in Walmart. In another shop it will be opposite, so what then ?
Silverliner
Re: 200 LPW LED GLS lamps coming out « Reply #13 on: October 12, 2016, 04:21:37 AM » Author: Silverliner
What do you think the future will be? You think LED filaments will be the standard or they are just a fad, a gimmick?
Electrician.
Re: 200 LPW LED GLS lamps coming out « Reply #14 on: October 12, 2016, 04:45:23 AM » Author: Ash
Standard, but not be the only type available
