Author Topic: EOL F40T12  (Read 3200 times)
RyanKorponay12
Ryan Korponay The Ballaster
EOL F40T12 « on: June 30, 2017, 03:09:17 AM » Author: RyanKorponay12
i want to force EOL on some cheep high hour alto lamps will a f96t12 do the trick? or should i use a 400 watt HPS balast  ::)
The Ballaster!!! *Poof*...
Re: EOL F40T12 « Reply #1 on: June 30, 2017, 10:12:59 AM » Author: Lumex120
I say do the 400w HPS. Just don't do it indoors and do it outdoors because the lamp will probably get very hot or even start melting.
Re: EOL F40T12 « Reply #2 on: June 30, 2017, 10:38:09 AM » Author: Ash
03:30 https://www.youtube.com/watch?v=aUA9aWPYRAA
RyanKorponay12
Re: EOL F40T12 « Reply #3 on: June 30, 2017, 11:50:17 AM » Author: RyanKorponay12
for the hps ballast do i have to change anything? or do i just replace the hps bulb with the fluorescent tube?
Re: EOL F40T12 « Reply #4 on: July 13, 2017, 09:50:35 PM » Author: xmaslightguy
Quote from: RyanKorponay12
No, it will run them at right around normal power.
A HO or VHO ballast might do the trick though (will also likely run them to vacuum loss :) )
