Author Topic: I saved 10 MH wall packs from being replaced to LED  (Read 3500 times)
RyanKorponay12
Ryan Korponay The Ballaster
I saved 10 MH wall packs from being replaced to LED « on: September 03, 2017, 04:48:22 PM » Author: RyanKorponay12
i work at canadian tire as a automechanic and i over herd my manager and some other people talking about replacing the lights outside to led becaues the old ones were supper dim/not working and there glass lenses were full of water, so i went up to them and i said i can give you guys some new bulbs and i can clean the water out, and they were supper thrilled, so i replaced 10 400 watt mh bulbs and cleaned ever singe one of them, im not sure what the brand is but there full cut off mh fixtures, the picture is from street view and this is before i did the relamping
goo.gl/Anm5sL
« Last Edit: September 03, 2017, 07:03:46 PM by RyanKorponay12 » Logged
The Ballaster!!! *Poof*...
589
Tha SOX MADMANNN
Re: I saved 10 MH wall packs from being replaced to LED « Reply #1 on: September 03, 2017, 09:19:22 PM » Author: 589
Nice!
You figure out and fix why they were full of water?
:lps:
RyanKorponay12
Re: I saved 10 MH wall packs from being replaced to LED « Reply #2 on: September 03, 2017, 10:04:20 PM » Author: RyanKorponay12
the previous person who replamed them didint know how to put the gasket on and just shoved it up in the ballast area so i took it out and put it back on
589
Tha SOX MADMANNN
Re: I saved 10 MH wall packs from being replaced to LED « Reply #3 on: September 03, 2017, 10:47:42 PM » Author: 589
What lazy people. Good to hear you figured it out.
:lps:
Re: I saved 10 MH wall packs from being replaced to LED « Reply #4 on: September 04, 2017, 01:38:23 AM » Author: Ash
If they fill uo like that without a gasket, they most likely will with the gasket too, after it was sitting for a few years in a hot area out of its intended place. Is there any way you can poke a tiny drain hole in the bottom in each unit ?
