Author Topic: 150 watt HPS in 70 watt fixture?  (Read 3967 times)
RyanKorponay12
Ryan Korponay The Ballaster
150 watt HPS in 70 watt fixture? « on: September 15, 2017, 08:13:52 PM » Author: RyanKorponay12
okay so my 70 watt hps fixture started cycling today and i dont have any more 70 watt lamps so i put in a new ge 150 watt lamp, will this hurt the ballast or anything? it runs about the same brightness just the colour is very orange like a lps
The Ballaster!!! *Poof*...
Lodge
Re: 150 watt HPS in 70 watt fixture? « Reply #1 on: September 15, 2017, 09:52:05 PM » Author: Lodge
You might overload the ballast and cook it.. just throwing it out there Canadian tire had the 70 watt HPS on sale by me for like $6 you should look at the one by you, they are a NOMA so not the best quality but they work ..
Lightingguy1994
Re: 150 watt HPS in 70 watt fixture? « Reply #2 on: September 30, 2017, 05:30:25 PM » Author: Lightingguy1994
RyanKorponay12
Your ballast will likely overheat and it may shorten your lamp life also. If you're in need of more 70w lamps, then check out This site , its where I've been getting some of my HID lamps at pretty good prices and they are located in Ontario Canada.
« Last Edit: September 30, 2017, 05:32:07 PM by Lightingguy1994 » Logged
