Author Topic: ballasts whats noiser  (Read 6657 times)
form109
ballasts whats noiser « on: July 18, 2008, 12:13:19 AM » Author: form109
although mercury vapor & metal halide ballasts seem to be prone to buzzing as they age,i would think any ballast would become noisy,if maybe the laminations,cane undone.
don93s
Re: ballasts whats noiser « Reply #1 on: July 19, 2008, 04:14:18 PM » Author: don93s
I've seen both MV and MH ballasts get equally noisy. The most common source of noise seems to result from the coil becoming loose around the core. I have successfully repaired this by applying class H transformer varnish on and around the coils...usually works like a charm. Problem is that the varnish that I have is hard to find....luckily I had some at work.
form109
Re: ballasts whats noiser « Reply #2 on: July 19, 2008, 04:31:41 PM » Author: form109
although its more expensive,why not use expoxy resin,if you pot the ballast with epoxy the ballast would be very quiet,also epoxy would last longer than varnish because it has a very high tollerance of tempatures,the epoxy also reduces hot spots on the windings,prolonging the life.
lite_lover
Darren
GoL darren.harward
Re: ballasts whats noiser « Reply #3 on: July 19, 2008, 05:14:46 PM » Author: lite_lover
Yes, any ballast can become noisy,even fluorescent and HPS.I have a couple fixtures with HPS ballasts, that are buzzing a little more than most.
The brighter the better.
GE M-400A1
My Pontiac 6000 STE
Re: ballasts whats noiser « Reply #4 on: July 20, 2008, 12:03:16 PM » Author: GE M-400A1
I used Epoxy on my Silverliner's Ballast and it sure made it quiet!
My Cars:
1986 Pontiac 6000 STE
1996 Chrysler Concorde LXi
1998 Chrysler Cirrus LXi
form109
Re: ballasts whats noiser « Reply #5 on: November 10, 2008, 06:31:29 PM » Author: form109
there is one flourescent fixture in my school that needs replacing the ballast hum is very prominent,the lamp has very blackened ends,and the old lamp is destroying the ballast!
i also recall a ballast in a flourescent fixture overheating,when it burned out it had the most awful smell!
