Author Topic: Pulse Start MH? Why no Pulse Start MV?  (Read 3733 times)
Pulse Start MH? Why no Pulse Start MV? « on: December 30, 2017, 05:46:39 PM » Author: HomeBrewLamps
So if pulse start MH lamps are more efficient than probe start MH lamps, why did they never develop pulse start MV lamps?
MissRiaElaine
Re: Pulse Start MH? Why no Pulse Start MV? « Reply #1 on: December 30, 2017, 05:54:25 PM » Author: MissRiaElaine
MV is quite an old technology, the MA lamps were developed in the 30's, the MB's not much later. No complex electronics around back then. They work. As the old saying goes, if it ain't broke, don't fix it. Although in a way, they did; MH iss basically a development of MV.
What I find strange is that probe-start MH is never seen this side of the pond.
« Last Edit: December 30, 2017, 05:57:04 PM by MissRiaElaine » Logged
Re: Pulse Start MH? Why no Pulse Start MV? « Reply #2 on: December 31, 2017, 03:26:41 AM » Author: Medved
With MV there is not much room to gain in efficacy, eventhe normal probe start are near the attainable maximum.
The omission of the probe is important only when you need to reach higher operating temperature of the fill, what is necessary for only MH.
MV are still operated way below what the probe design allows, so no benefitt to complicate the ballast.
The probe start MVs didnt make it to Europe (except some early experiments) because they need higher ballast OCV for reliable starting and operation. In the US this was no big deal, as the ballasts have to be already an autotransformer, so increasing the OCV makes no extra trouble. But in Europe (and all 230V world) the MVs sufficed with just a series choke (well, their electrical specs were intentionaly designed so, because just a choke costs half, weighs nearly half and has half losses compare to a transformer basedballast). To suffice with just 220V OCV, they had to reduce the arc voltage, so increase the current. But that means the burner became shorter and thicker. With that, the wide seal necessary for the starting probe would obscure too much light and dissipateway too much heat (so make the already tight thermal budget even tighter), the lamp efficacy would be too low. Anddont forget, the probe brings reliabiliry problems into MH too (when voltage present between theclose spaced electrodes, the MH environment yields severe electrolysis corrosion, so a switch had tobeused to short the starting probe to the main electrode, so extra complication and extra issues; the puremercury inMV is quite inert, so no such problems in the MV).
To start the lamp without so much arcvoltage reduction needed some voltage boosting, so an ignitor. And when the ignitor was present, it was not much extra complication to make the ignition pulse high enough, so the troublesome starting probe could be omitted.
But in recent years, pulse start MV was brought to the market: Because of the MV ballast ban in the US, EYE lighting (Iwasaki) introduced an MV lamp designed to operate on a pulse start MH ballast, for applications requiring clear MV light color. Because it was designed to operate on a ballast generating HV pulses, the internal construction need to assure sufficient dielectric strength (except the arc cavity itself, of course). Andthat means the starting probe and its resistor had to go away, as they would become the weak point there.
Re: Pulse Start MH? Why no Pulse Start MV? « Reply #3 on: December 31, 2017, 04:46:39 AM » Author: Mercurylamps
In 240v land (ie UK and Australia) having a auxiliary starting probe with a resistor connected for mercury lamps is very common. It makes the control gear simple only requiring a ballast (and PF capacitor if necessary) for wattages up to 400 or so.
Re: Pulse Start MH? Why no Pulse Start MV? « Reply #4 on: December 31, 2017, 05:11:51 AM » Author: Ash
The very first Soviet Merc's were actually Pulse Start, the reason as far as i know was that they had some trouble in sealing 2 electrodes (the main and the probe) in the same end of the arctube
The ignitor was something like a capacitor charging up through resistor, and then discharging through a Neon (acting as a spark gap) into a tap on the ballast. I guess that the Neon was chosen so, it would not strike if the Merc lamp is working
In the ~70s Israeli company Electrical Works of Ein Hashofet made the ES50, a SON ignitor with virtually the same concept, except the Neon was replaced with a diac. (i wonder if they actually seen the Soviet ignitor when designing the ES50)
Re: Pulse Start MH? Why no Pulse Start MV? « Reply #5 on: December 31, 2017, 01:37:15 PM » Author: HomeBrewLamps
Does somebody around here own an early USSR Mercury lamp?? I'm curious to see one of these ...
