Author Topic: MV on PSMH ballast  (Read 2949 times)
MV on PSMH ballast « on: December 30, 2017, 06:45:19 PM » Author: wattMaster
Will a MV bulb work on a PSMH ballast without the ignitor? I measured it and the ballast used a little less power than usual, so it must be underdriving the lamp a little bit.
Re: MV on PSMH ballast « Reply #1 on: December 31, 2017, 02:02:02 AM » Author: Lumex120
Yes, but for wattages under 175 you have to use one wattage lower on the ballast, e.g. 70w for 100w MV, 50 for 75, 35/39 for 50.
Re: MV on PSMH ballast « Reply #2 on: December 31, 2017, 03:02:12 AM » Author: Medved
For a 175W lap you need 150W ballast and for higher wattages there is no directly suitable combination (unless you can tolerate some underpower, then for a 400W MV you may use 250W pulse MH ballast, it will drive the lamp at about 320W).
Re: MV on PSMH ballast « Reply #3 on: December 31, 2017, 05:15:18 AM » Author: Ash
Gotta name also 70W ballast / 100W ballast for 125W Merc, 2 combinations i seen being used here with good results
