Author Topic: LED installation causing issues with historic lighting  (Read 12614 times)
Econolite03
Matthew E.
Re: LED installation causing issues with historic lighting « Reply #30 on: October 07, 2021, 06:55:30 PM » Author: Econolite03
I’ve seen those, they’re neat. Too expensive for my taste though.
Re: LED installation causing issues with historic lighting « Reply #31 on: October 07, 2021, 07:37:20 PM » Author: Mandolin Girl
IDK what the old lights were, but they replaced them with Leoteks that self destructed. Apparently the surge suppressor and photocell just turned into melted globs if I remember correctly.
That's what happens when you shove too many volts through them...  :eoled:
Re: LED installation causing issues with historic lighting « Reply #32 on: October 07, 2021, 09:32:24 PM » Author: joseph_125
That's weird. Clearly they weren't meant for series lines!
AFAIK, I don't think they make LED luminaires with drivers that can operate off a 6.6A system. Your option is to either stick with HID, rewire to multiple, or install one of those 6.6A to 120v isolation transformers designed for LED conversions to the pole and run conventional LED luminaries.
Re: LED installation causing issues with historic lighting « Reply #33 on: October 08, 2021, 07:59:53 AM » Author: Mandolin Girl
Sounds as if it's a lot easier, and cheaper to relamp the fixtures with HID.  :wndr:
