Author Topic: HID lamps on NST's  (Read 2932 times)
HID lamps on NST's « on: March 29, 2019, 05:37:44 AM » Author: HomeBrewLamps
What would happen both in the long term and short term if you ran a HID lamp on a neon sign transformer? I have a few 3000 Volt NSTs and I've been tinkering around with HID lamps on them... The 175watt mercury lamps look pretty cool running so dim.. 1000 watt high Pressure Sodium aswell.
« Last Edit: March 29, 2019, 05:43:50 AM by HomeBrewLamps » Logged
Re: HID lamps on NST's « Reply #1 on: March 29, 2019, 05:47:28 AM » Author: dor123
Running an HID on a NST,  is like running them on an ignitor, so they would only exhibit a HV cold cathode discharge. This can ruin them fast.
Re: HID lamps on NST's « Reply #2 on: March 29, 2019, 05:15:27 PM » Author: HomeBrewLamps
Good to know,
I guess I will not run HID lamps on NSTs.
Re: HID lamps on NST's « Reply #3 on: March 30, 2019, 06:30:34 AM » Author: Ash
Running in cold cathode mode will sputter the cathodes and blacken the arctube. But it can't be fast with 30mA ish of current.. I think trying to light it for a few seconds or 10's seconds won't do anything noticable to the lamp
If you have a leaked / broken arctube lamp then it is great for such test. Bet the discharge will look beautiful
